Cheap Multi tool Seen at Lowes
I was wandering around in Lowes last night killing tome when I notice they have a Bosch Multi-X tool on close out for $80. The salesman Thought there must be a new model coming out soon and that Lowes would carry that.
I have no relationship with Lowes or Bosch, but I do own one of these tools that I bought on close out on a whim a year or two ago. I thought it was a sort of silly tool. Boy was I wrong. I have found fifty uses for it. I am not claiming it is as good as a Fien, but I really do like mine. It comes with an adapter disc allowing you to use almost every other brand of blades.
The one I saw was at the Lowes near Chesterfield Town Center. Might be worth a look.
Re: Cheap Multi tool Seen at Lowes
Dale Lenz
Dale Lenz
Re: define "near"
Al Stokka - Cambridge, Iowa
Ken,
If "near" can be defined as under 1000 miles...Yup, right next door @ 868.6 miles. ;^)
Al
Yonak
I have a Bosch 12v lithium Multi-X tool that works fine except that the battery seems to lose juice pretty quickly, so I can only count on it as a spot-job tool. If you need one for lengthy operations, you might look for a 120v tool. ..My 2�.
I was thinking that perhaps other Lowes stores might be discontinuing theirs also. If I were Lowes I would have a store in Sunny anyplace. The only reason I put the actual location in was in case somebody local wanted to rush right over and buy it.
I tend to agree. I bought mine at Lowe's from their closeout bin. I suspect it had been returned. The charger was defective. I called Bosch and they sent me a new battery, hoping that was the problem. Did not help, so they sent me a new charger. They did not want the battery back, so now I have three batteries. the run time on the batteries is about 18 minutes, according to Bosch. They charge in about half an hour. I find the batteries to be adequate for the types of things I do with it. I have not done much sanding with it,but I suspect that type of loading on it would deplete the batteries very quickly.
All in all I like the rechargeable version well enough, but i think I would prefer the corded version even more.
Ken Oakley-Sunny St. Cloud, Fla
While Sunny St. Cloud does have a Home Depot, a Walmart Super Center, a Staples and all the famous fast food places, we do not have a Lowes. There is one in Kissimmee, about 15 miles from here, but I can't think of much that they would have to make me travel that far. I was just pulling your chain which I have been known to do.
15 miles is just a good walk.
Galen Vetterick
That's how far I used to have to walk to school ..
Yonak
..in the snow .. wearing my sisters shoes .. uphill both ways .. after milking the cows and feeding the chickens, etc., etc.
Re: That's how far I used to have to walk to schoo
Carol Reed, Strawberry, AZ
Gees, Moses. I think you are about to find out that the first liar doesn't stand a chance! :)
