OT - split in a galvanize "Tee"
Naturally swapping it out would be a MAJOR PITA. There are nipples on both sides and a valve in close proximity to the "Tee".
The person neglected to drain the "Tee" in the cold weather last winter. Now that it's getting hot, they would like the waterers up and functioning.
Any thoughts? As I said, it would be a big problem to swap out the "Tee" - but I'll do it if it necessary.
Re: OT - split in a galvanize "Tee"
You'll need 2 unions, shorter nipples, a new tee, wrenches and a Sawsall. Where you put the unions depends on where your 1st right angle occurs in each branch. Your other options are to replumb in copper or put in a PEX manifold and home runs to each fixture. A good PEX clamp tool will run you about $350, but you'll use it more and more.
Bill Howatt
You know as well as I do that replacing it is the proper repair. If it is outside and leaking due to a poor repair won't cause any damage other than annoyance I'd probably try epoxy or some of that "magic" stuff I've seen advertized on TV (can't remember the name).
I guess brazing might be an option if you have a good torch.
BIll
FredD
Heat shrink tape is a fast temporary fix, it sounds like a thirty minute job for a Plumber, know one?
Have a air connection installed, so you can blow the system in the fall , only good way to rid it of water.
FredD
Clint Searl
Oakey plumbers' epoxy putty
Clint Searl
Five minute job -- that's how long it takes for the putty to harden. Trust me!
Clint
Joseph Mulherin
I agree with Mark...do it right as he suggested with unions and nipples. And I am a retired pipefitter/plumber
Vote against brazing
Neal in San Jose
First, it would be difficult to get a used fitting clean enough to be successful.
Second, heating a galvanized part hot enough to braze would release some very nasty gasses. In an enclosed area like a crawl space (where I'm guessing this is located), it could be really bad news.
That's What I Get
for marrying a Master Plumber's daughter. :D :D
John Veerkamp
I've had fair success with JB Weld. Clean and rough up the surface. If possible put something like a hose clamp over the top for added pressure protection. or a couple of hose clamps securing a piece of metal over the JB Weld.
Will try the Oatey.
