Dovetailing question
Bill Tindall
The situation: Typical cabinet wood-walnut, cherry, etc. the operation is wasting material between pins or tails and the length of material(length of base line between pins or tails) to be wasted is say 1" or 1 1/2". What size chisel do you use to chop/pare to the base line of the dovetail?
Do you use a wide chisel so as to whack out as much as possible per chisel setting, but with greater force because of the longer shaving? Or, to minimize whacking force on the chisel do you elect a smaller chisel- say 1/2" or 5/8- so that lighter taps can be used to drive the chisel.
I use, and have seen used, a smaller chisel so that light taps can be used to drive the chisel. But I would like to know how typical this choice is. What is your "go to" chisel width for waste chopping when the amount to be wasted is an inch or more?
(information needed for a chisel test)
