Drill Press Modification
Jim Toews - Walla Walla, WA
Hey All,
I may have just reinvented the wheel, but I have a very stiff table height adjustment mechanism on my drill press, to the point of the crank handle having snapped off several times (replacements aren't that expensive, but it's a real pain when it happens). I have tried cleaning off the gunk they slather on for shipping, as well as lubricating the mechanism, all to no avail. This morning it occurred to me that a simple ratchet mechanism might be easier to use, so I drilled and tapped a 9/16 3/8 drive deep socket for a set screw and attached it to the spindle: voila! It is amazingly easy to raise and lower the table with my long ratchet attached. Like I said, this may be old hat to most people and I may be finally seeing the obvious, but it is a major improvement in function for a frequently used tool. On the other hand, I may have just set myself up for an even bigger parts failure in the future. Time will tell, but for now I'm quite pleased with it.
Cheers!
Jim
