Unisaw on CL *LINK*
Andy Lincoln,in Dearborn MI
Hi All,
Not mine,no affiliation,yadda yadda,yadda.with the talk of table saws lately thought someone may be interested.
unisaw on Craigslist
Unisaw on CL *LINK*
Hi All,
Re: Unisaw on CL
Steve Schoene
Notice that this is a 3 phase motor--ie. 208 voltage, indicating it most likely came from a industrial or commerical setting.
Don't think So....
208 volts is single phase and comes for a "wye" transformer while 240 comes from a delta transformer.
Many motors are rated for both 208 and 240. We don't have the 208 locally, that I am aware of.
Not quite...
John in NM
The 208 V is measured between any two legs of a 3 phase transformer. The hots are 60 degrees out of phase rather than 90.
120V hot to ground, 240V*sin(60)=208V hot to hot. For single phase it's 240*sin(90)=240 hot to hot
When ever I've seen motors rated 208V they are always 3 phase.
Re: Don't think So....
Steve Schoene
There may be some 208v/230v motors that are single phase. That's an electrical engineering question far out of my expertise. But were any such motors made for the Unisaw--it is a special purpose mount, you can't just bolt an odd motor on a Unisaw. As far as I have seen there have only been 115 volt and 230 volt single phase motors and 3 phase motors, which have been 208 volt.
Re: Unisaw on CL
Moses Yoder
There is a good chance this guy bought it at auction not realizing it was 3 phase and never hooked it up. Now he wants to sell it without telling people it is 3 phase. I bouhgt my 3 phase Powermatic 66 for $80 cash plus a nice compound bow, and have put an inverter on it. It runs great and I love the saw but getting it running took some time and money because it was three phase.
Re: Unisaw on CL
Chuck Jurvelin
I went to an auction several years ago that was selling equpment from a high school shop class. Nice stuff, but all three phase motors. I mentioned it to the guy standing next to me that it was too bad it was three phase, to which he replied "Big Deal!" After he got the winning bid on two very large pieces, I heard him ask someone else "What do they mean by three phase?" I hope he enjoyed his bargains.
Re: Unisaw on CL
Barry Mabery
I recently bought an early Powermatic 66 off CL that was several hundred dollars below the going rate in the NJ-NY-CT area, advertised as "3 phase". I thought, "OK, buy a VFD, wire it up and I'm still ahead on the price." However, I suspected that the owner was misinformed because the motor closeup showed two nice capacitor bumps, which are not present on 3 phase motors.
When I met the owner I found that it had been in his uncle's small commercial shop for years and that he had never tried to use it with no 3 phase available, as indicated by the 3 Phase Y 120/208V plug (L18-20P). Couldn't see the motor nameplate with it mounted. So, deal done, I took it home, and removed the motor, which clearly states "1 PH 220V". I checked the wiring and found that only two of the three hot leads were connected to the manual starter and motor. Changed the plug to an L6-20P 250V, plugged it in to a switched receptacle and gave it the "bump test". The motor fired right up. Tried a longer test and it went right to the 3450 RPM speed.
The lesson I learned is, don't pass up a 3 phase machine if it's what you want and the condition and price are right. Sometimes you just get lucky, though.
