Making tenons
Making tenons
Making tenons
Dave in Bryn Mawr
We all know there are many ways to cut tenons. I have tried most of them I think (TS, router, by hand, etc.) and have finally decided on my favorite: the bandsaw (for small pieces anyway - tables, etc.). No fancy jigs - just a 1/2" blade, fence and miter guage - cuts cheeks and shoulders, and you can SEE what you're doing. I recommend it.
Re: Making tenons
tell us more
Bill Tindall
Exactly how are you cutting them? Scribing a line and cutting to it. or setting up a fence. If a fence, what technique is used to get the thickness right?
Re: Making tenons
Re: Making tenons
paul in AZ
I use my miter saw for the cheeks and shoulders and the bandsaw for the tenon itself.
Adjust the miter saw blade for cutting depth; use a stop block set to the cheek line for tenon length. This way I get very accurate, perfectly clean cheeks in no time at all.
I scribe the tenon and cut it on the bandsaw. Usually a hair oversize so a pass with a rasp will make it fit snugly.
I suppose the table saw could replace the miter saw but like Dave i like to see what I'm cutting. I also think the miter saw arrangement is more accurate.
Re: Making tenons
Re: Making tenons
Paul, what kind of miter saw are you talking about? I could not do it with my chop saw, at least not well.
Re: Making tenons
Re: Making tenons
paul in AZ
Its a Makita LS 1013 CM Saw and has an adjustable screw that limits the depth of cut. I just do a couple of trial cuts on scrap of the same thickness to get the right depth. Very handy.
Re: Making tenons
Moses Yoder
Re: Making tenons
Moses Yoder
When I have a bunch of tenons to make I cut the shoulders on the table saw and the cheeks with a band saw. I use a rabbetting block plane or a shoulder plane to pare the tenons to fit.
Re: Making tenons
Re: Making tenons
FredD
The Table saw is the tool of choice for cutting Tenons for me.
When I am doing Tenons on 3/4" stock , the depth set for the Tenon also is the same for the shoulder and I just run it around all four sides .
If one uses a a little extra care in depth setting , it will eliminate most , if not all fine tuning .
At least for me .
FredD
Re: Making tenons
A time-honored way indeed
It's a bit more work because you have to plane the surfaces smooth, but bandsawn tenons are perfectly respectable. Thanks for the reminder.
Re: Making tenons
Re: tell us more
JimG
I do both. I scribe the lines, then I set the fence to cut the shoulders, then move the fence for the cheeks. I cut it a bit shy and clean it up with a LV medium shoulder plane. Works very well.
JimG
