(Message Deleted by Poster)
Mark Meier (Ann Arbor, MI)
hopeless
Bill Tindall
Water is a very small molecule and it passes readily through the molecular structure any plastic, including all the finishes. The finish will certainly slow the rate of moisture equilibration of the wood with air, but given time the wood will be at the same moisture content with or without finish.
An example of this permeability can be illustrated with a plastic soda bottle. Pick a small size where the surface area to volume is unfavorable and let it sit on the shelf well past its expiration data. 6 months on the shelf and it will be noticeably "flat", having lost much of its carbon dioxide through the side walls.
The reason beer is not to be found in plastic bottles is oxygen goes the other way. Oxygen permeability into the bottle makes beer task even worse than I think it does to begin with. Plastic bottles can be made less permeable to oxygen but they are very expensive to make.
'Tis The Holy Grail You Seek
Been searched for for thousands of years, along with that board stretcher trick. Ain't been found yet, but let me know, please, if you find either of them. I could especially use that stretcher
Re: hopeless
Neal in San Jose
The best you can hope for is to slow it down. There are charts that rate the relative speed of water transfer (wax is usless, shellac is somewhat better, a 1/4 inch thick layer of the pour-on bar top stuff is pretty effective), but nothing stops it.
Ahhh... it's a matter of time
I see, it'll slow it but not prevent. Got it.
Thanks,
Mark
Re: hopeless
Sgian Dubh
Not entirely hopeless, because the thicker the film of polish on the surface the more effective it is at reducing the speed at which water vapour can either get into the wood or, conversely, leave the wood.
However, to set against that, some film finishes (such as pre-catalysed and acid catalysed lacquer) crack due to the inbuilt stress built up in the film thickness if the film thickness exceeds approximately 100 microns. Therefore pre-cat and acid cat lacquers are two finishes you can't make more effective as a vapour barrier through thicker coating. Slainte.
I had a board stretcher, but threw it away...
Every board came out looking quartersawn if you were greedy and stretched them far enough.
Infancy Gospel of Thomas...
Chapter XI.-How Jesus Made a Short Piece of Wood of the Same Length as a Longer One.
And Jesus reached the age of eight years, Joseph was a master builder, and used to make ploughs and ox-yokes. And one day a rich man said to Joseph: Master, make me a couch, both useful and beautiful. And Joseph was in distress, because the wood which he had brought for the work was too short. And Jesus said to him: Do not be annoyed. Take hold of this piece of wood by one end, and I by the other; I and let us draw it out. And they did so; and immediately he found it useful for that which he wished. And He said to Joseph: Behold, do the work which thou wishest. And Joseph, seeing what He had done, embraced Him, and said: Blessed am I, because God hath given me such a son.
That's One
But last time I inquired, it wasn't out for retail. I asked the monsignor when it might be available. He said it would probably be some kind of miracle if we saw it again; mentioned something about a "Second Coming."
Meantime, I have to do that "measure twice" thing.
Do I see my Name?
My Gospel.....
And I sayeth to all visitors to my workshop..."look around and enjoy, but don't touch the tools for thouest will surely suffer a great loss of fingers". Here endeth the Gospel of Tommy. ;-)
Re: hopeless
FredD
Richard ,
that is why any of the Pre-CAts I have used and even before with Nitro Cellulose Lacquer when they started selling Vinyl pellets as a vapor barrier additive, all recommend a vinyl added sanding sealer before the lacquer .
Vinyl containing finish has the highest of all vapor barriers ratings.
FredD
This Time Saturday
You (and I) won't need fingers if old Zeke has his way. I just bought green bananas so I'm betting against him.
Re: hopeless
Sgian Dubh
True Fred. However, my recollections of vinyl sealers (which I haven't used now for perhaps ten or twelve years) is that they can tend towards a little milkiness, opaqueness, call what you will, that slightly inhibits clarity.
My memory may be a bit off, and it may be that the clarity issue has improved. On the other hand I can't recall ever seeing vinyl sealer available over here in the UK, although I did come across it during my ten year sojourn in Texas. It's been eight years since I lived there so I've not been able to asses vinyl sealers since then.
On a side note, I must admit I have no idea what inspired these odd posts about Jesus, board stretchers and other stuff. Maybe it's because I'm not religious and can't see the link, ha, ha. And I also wonder why the original question was deleted. I don't need an answer to either of the comments I've made in this paragraph-- I simply note the rather strange direction the thread has taken. Slainte.
Guilty
I used the "Holy Grail" term and included the board stretcher as the other unobtainable woodworking aside for a coating to halt seasonal change. JL laid the familiar scripture on us and I responded with a bit of personal history. It's all in good humor so let's not make more of it than there is, shall we?
ps the original post wanted to know about a coating that would stop seasonal expansion and movement in wood parts. Have no idea why the OP bailed; certainly a valid inquiry.
Re: Guilty
Sgian Dubh
Mark, I read the original question, hence the nature of my first response. It seems curious to me that the question (a reasonable one I thought because I assume the questioner didn't know the answer) was later removed.
As to the religious stuff I realised there was some joking going on-- I just couldn't see where it had come from, and didn't understand it. Maybe I should have read the posts a bit more closely instead of glazing over and skimming those posts. Slainte.
Not Guilty
Have no idea why Mr. Meier deleted his own post. There was nothing objectionable in them.
BTW, I did have that conversation with a monsignor when community volunteers were doing some work for his church. He was right on the joke as his response didn't hesitate but a few seconds.
Casey Stengel
paul in AZ
Maybe the world will end tomorrow but Casey Stengel got it right. "we should never make predictions, specially about the future".
Re: hopeless
FredD
Richard,
I have not noticed a opaqueness with Vinyl containing Sanding Sealers, but that doesn't mean it doesn't occur.
Just means your eyesight is better then mine.
What I did notice right away and it still remains that way over the ten years I have used them , Vinyl Sealers do not sand nearly as easy or as fast as the old Nitro-Cellulose ones and they load the sand paper rapidly , but in my view are still worthwhile for the Vapor barrier they form.
FredD
Re: hopeless
Sgian Dubh
Fred, I'd forgotten about vinyle sealer being harder to denib between coats, but you've reminded me of that fact-- you can see how long it is since I used the stuff.
I wouldn't say my eyesight is especially good, especially now as I'm getting older, but I frequently surprise my students, many of whom are in their late teens or early twenties (presumably with good eyesight therefore), when I pick out flaws in their wood prep and the finish applied to their projects. Most say they can't see the flaws I see until I spend quite a bit of time demonstrating how to see them-- actually I feel a lot of them with my fingertips, and get the learner to copy what I'm doing to spot them. I put my ability to nitpick over the quality of a finish down to nearly forty years of learning how to look, and what to look for, so that customers don't reject items because of finishing faults, ha, ha. Slainte.
