Getting the paint off.
I've cut up the old church doors and salvaged the rails and stiles. They have a bit of paint on both sides. The doors are red oak. I was going to salvage the lumber to use in another project for the church.
Just plane it off (and collect the planer dust and throw it away so it won't go into my compost pile)?
Strip and sand?
Cut it off with my jointer?
Re: Getting the paint off.
Nat Robison
Someone correct me if I'm way off, but I believe you're NOT supposed to remove paint with a bladed power tool since there are elements in the paint that will tear the blades up. Better to go with a stripper.
Partially Agree With Nat
George Colonel's Workshop-Havertown PA
Good Afternoon JL,
I sure wouldn't use new(ly) sharpened planer blades. But I did use dull and knicked ones on a quantity of recycled American Chestnut which had 80 years accumulation of white enamel. Once they had done their job I had them resharpened @ Scott's Sharpening Service to perfection. Its the easy way, and I'd do it again in a heart beat.
George
Re: Partially Agree With Nat
Steve Schoene
A blade sharpening is cheap compared to the money and effort involved with using stripper. Besides clear finishes, in particular, will have very little in them that would dull blades.
But, be sure there is no imbedded metal someplace you don't expect it. Now that can chew up blades.
Howard Acheson
If you plan to re-stain the salvaged wood, I would recommend using a chemical paint stripper to remove the old finish. Red oak has large and deep pores and the prior finish will have soaked into the bottom of the pores. Unless you plane deeply into the wood, you will not remove the deeply imbedded finish. This residual finish may cause a future stain to color unevenly.
While stripping can be a bit of a mess, using a good stripper that contains methylene chloride will do a reasonably fast and complete job of removing the finish. If you get a "water rinseable" stripper you can use a hose and stiff scrub brush to quickly remove the dissolved paint.
The paint was finished first and then painted. I've removed the hardware that was on the door. Underneath the hardware was finished (but not painted) wood.
Watch out for LEAD
Mike Farinella
please dispose of properly if it tests positive for lead.
Randy
If old probably have lead paint, be sure whoever removes is Lead Certified. Could apply some sodium hydroxide to remove it and neutralize with citralic acid.
