OT-Water Pressure Question
Nat Robison
My house is on city water and has generally decent pressure, there's some drop when using 2 fixtures but generally, it's fine. The pressure seems to be lowest at the hose bibb on the front of the house, which is the longest plumbing run in the house.....half of the run being 1/2" pipe. I bought an inexpensive tester and got a psi around 75 (I think low is under 40 or so).
Would I gain anything by installing a new hose bibb about 8 feet from where the service enters the house, supplied by 3/4" pipe with a ball valve on the end? The existing hose bibb is about a 40-ft. run of pipe. I could switch both the front and rear hose bibbs to 3/4" supply relatively easily but would it improve the pressure?
Re: OT-Water Pressure Question
FredD
You would increase the flow with a larger supply line , but the pressure will remain the same.
FredD
Let me clarify.....
Nat Robison
I get your point and I understand there's a difference between flow and pressure, as much as someone who's not a hydro engineer can, anyway.
Basically, I want my sprinkler to reach farther and be able to hose off my car with "more" water. I guess I'm just using the term "pressure" for my impression of how much water comes out of the hose.
Seeing how my house seems to have adequate pressure, would the new line accomplish my goal?
Most likely
Lee Schierer McKean, PA
Most likely your new line would deliver a greater volume of water with less pressure loss with 3/4" pipe. The flow in an old 1/2" pipe can be significantly reduced inside by scale and rust build up. You could also replace the 1/2" pipe at the current location with new 3/4" pipe and see much less pressure drop.
Lee
Another thing
Gary Camp, Bend Oregon
Most hose bibs have a smaller orifice the the pipe size, this increases friction loses and decreases the flow rate. Most ball valves are full flow. You might try just changing from a hose bib to 1/2" ball valve and achieve satisfactory results. At my home I am going the 3/4 ball valve route and plumbing them in such a way that they will be "frost-proof" too (I hope).
Re: Let me clarify.....
George Koch
Nat, you never mentioned what diameter of hose your using. It wouldn't help much to change your hardpiping if your using a 1/2" or less hose size.
Thanks and answers
Nat Robison
Thanks for the input. I guess the way I understand it, the more water you can put where you want it (flow) under decent pressure, the better.
I could repipe the current supply but it's currently covered by drywall and with the price of copper, I'd probably put in a new supply anyway. I could run 10 feet of new supply to its current location or rework 30 feet of the original supply. I'm not sure why the original plumber didn't do it that way anyway.
My current bibb has a ball valve so it's the best I can do but it's not great. My current hose is 5/8" (I think) and 100 ft. long. I know that can adversely affect "pressure" but I have a big yard. I was looking at gate-type hose bibbs at HD and noticed that many of them choke the flow down through about a 3'8" hole. That can't be ideal.
Re: Thanks and answers
As a Home Inspector I check water "pressure" everyday. I used to carry a pressure gauge and quickly learned it did not tell me what people wanted to know. Pressure gauges test "static" pressure. that's the pressure inside the system when it equilibrates with the water standing still and its fairly meaningless.
What you are looking for is a combination of volume and flow. If the flow is restricted, the volume will decrease and the pressure will drop off as the water starts to move in the system. The way I test it is to go to the upstairs bathroom furthest into the system and turn on the shower. I observe the flow and assure myself it appears adequate to take a nice shower. Then I turn on the sink and flush the toilet and observe the flow, to see if it diminishes. I learned the hard way that nobody cares if there is "X" PSI of pressure if the shower falls apart when someone else uses water and robs them of the volume and pressure.
So you have figured out your problem. The longer the pipe run, the more flow it robs you of. The smaller the pipe is, the more it robs you of flow. The valves matter somewhat less because of the Venturi Effect. You can jamb a lot of flow through a fairly small hole like an orifice if the restriction is short. But a bigger valve is still better. So, You have the right Idea. Use the shortest run of the larger pipe with bigger valves and you will get the best result you can with the water available to you.
Another thought. I reported to one of my clients they had very poor Pressure/volume. The city came out and took out his water meter. The guy who looked more like a grizzled old fart that a hydraulic engineer attached a hose where the meter had been. It was a large (3/4"?) commercial hose with a three foot length of 3/4" pipe on it. He pointed the pipe up and about a 45 degree angle and turned on the water. The water arced up about two feet and landed about six feet away. He announced "There's your problem, city ain't got no pressure. You need a new water main." I asked how he knew that and his answer was that if it was working like it was supposed to it would have shot the water clear across the street. There were six houses on a two inch water main that was fifty years old. They put in a new one and sure enough the pressure and flow went way up. Then they wanted me to pay for all the new upgrades they needed to their plumbing to handle the new pressure.
The point is that if your restriction is in the system before it gets to your house, your new work won't help much, But you say your flow is good elsewhere, so hopefully you don't have that problem.
Bill Tindall
pressure at the end of a line depends on the diameter of the pipe and the flow rate through the pipe. Flow rate through a pipe depends on inlet pressure and length and diameter of pipe. You can easily find tables on the internet to enable you to calculate what ever is of interest. Look for "friction losses in pipe, water".
There is a huge difference in pressure loss per ft of pipe.between 1/2 and 3/4" pipe at 5 gal /min. , for example.
Bill Turpin in WNC mountains
A 3/4" hose will carry 2.25X the flow of a 1/2". .4417 sq in vs .1963 sq in. A good plumbing supply should stock FULL flow hose bibbs. The seat diameter will equal the pipe diameter. Ball valves are also available with thru holes equal to the pipe size. Both of these cost more than standard small flow valves.
Static pressure of 75# is plenty. Most home well systems operate between 20#/40#. On at 20#, off at 40#. You have flow problem, not a pressure problem.
A 1" full flow fire-sprinkler valve will flood a 15,000 sq.foot building, 3 inches deep in about fifteen minutes. Sprinkler system was feed by 8 inch, full flow valves, at 125#.
FredD
Why would your "client" ask you to pay for a City utility maintenance problem?
That falls under Public Works department jurisdiction , not a home owner responsibility.
FredD
