Processional torch diameter and base questions *LINK*
I'm ready to start work on some processional torches. Before I do, I have to decide what is a "reasonable" diameter.
As the poles are wood (cherry to be exact), I don't want them to be "whippy" or bend. The oil-filled candles that will be used for the torches are 1" in diameter.
I was thinking of something on the order of 1 1/4" in diameter. This would accommodate the 1/2" all-thread that will be used to "attach" the candles. I could decrease the diameter if ya'll thought that would work better. I "tested" the acolytes hands and they can all grip 1 1/4" quite reasonably. CM Almy has their long (46") torches at 1 1/4" in diameter. As these torches are going to be similar in height, I was figuring on making them 1 1/4".
In terms of the floor bases, I am going to have to add some weight to them. I was figuring on melting some wheel weights and casting some weights to attach on the bottom of the bases. I can easily drill some holes with a Forstner bit in some scrap lumber and use those holes as molds for the lead.
Does this sound reasonable?
. I'd have to go buy shot.
