Templates and more templates
Stephen Kirk
For some of our people who might not be used to templates, I thought I'd mention just how useful it is to take the time to make them. Often, if you want something really exact, it could take several tries. Patience and perseverance is definitely in order.
In the pic here, I was working on a template for the seat rail portion of an adirondack chair. Thing was, it had to fit into a different style of chair. The top wooden template is from Norm's adirondack chair in PW. I only needed the seat section, so I made some paper versions. I cut another one out of plywood and discovered it didn't fit the space as well as I would have liked. The straight sided plywood template on the bottom is what the plan called for. I cut that to see how it would fit, then laid out a new curved template on paper to more closely match the planned one. Finally, I got to the hardboard version on the bottom. Take your time sanding and cleaning the edges to make the curves really smooth and flow correctly.
I was labeling as I went. Certainly, if you make a bunch, don't get rid of any. Label them up and wait for another use.
Good thing is, these are pretty permanent. It's easy to outline it on the wood and saw it close to shape. Stick the template back on with some double stick tape and rout it perfect or just sand up to the line. You'll get exact matches every time.
Hope this can help someone out.
Re: Templates and more templates
Yonak
Hi Stephen. I agree guides are indispensable. I have had good luck making full-sized CAD drawings, affixing them to the wood and cutting and sanding to the line. The curves are always graceful and accurate as I don't always trust my vision in that regard. If the project requires multiples of the piece I make a wood template using the CAD drawing.
Re: Templates and more templates *LINK*
Stuart Johnson
Joe Johns has posted a Youtube video showing some of his processing jigs.
Joe Johns jigs
It Makes A Person ConTEMPLATEive, Dontcha Think?
All is right with the world
When the Colonel is back to making puns, everything's OK on Wood Central.
