REAL MILK PAINT
Lumber stored outdoors for years
Bill Lordan
Last year I bought a pile of rough cut lumber of a former woodworker who had stored this lumber under a tarp for years. I did the same thing with it until this morning. I was going to move it into my garage to start drying it out when I noticed very tiny bugs crawling all over the lumber - they appear to be the size of fleas. Does anyone have any idea what these insect would most likely be and would they infest the house. I had hoped to use the lumber to build an arbor for my wifes grape vine but I will just burn it if it is totally useless. Thank you in advance for your advice. I have tried to include a picture.
Bill Lordan
Auburn, NH
Re: Lumber stored outdoors for years
Chuck in Mtl.
sounds like it needs to have more air circulation because the wood may be decaying under the tarp? Remove the tarp and possible spray it with a borax solution to kill the bugs.
Dale Lenz
Dale Lenz
Sounds like the bugs found a moist place to call home probably silverfish etc. Bugs will leave once lumber gets drier. Sticker the boards in your garage for a few weeks, no need to dry down very far as you are going to be putting the wood outside to live.
Air dry outside
Tom Dunlap
Besides the bugs that might be on the wood there are likely some molds and fungi that could be unhealthy. I wouldn't be too quick to bring that wood indoors.
I'd take the pile apart and lean all of the boards vertically against the wall outside. As you expose each plank a quick broom sweep to get rid of lose stuff. Then, a solution of bleach, insecticide/borax might be in order. Using a five gallon pump up sprayer is a quick way to add the wash.
After the wood's dried I'd restack and sticker with lots of air space outdoors.
When it comes time to surface and prep the wood be aware that your dust mask/respirator might need new canisters to capture the fungi and small stuff before it goes into your lungs.
I had some wood like that. As much of the prep was done outside on a breezy day. When I was done I undressed in the shop, shook off the clothes outside then washed them using the XL load so that I had lots of HOT water. Having rogish fungiis lurking in my clothes is not a pleasant thought.
Tom
Sure wouldn't want that wood in your house
del schisler
I wouldn't want that wood in your house tell i know what they were and killed?? Ask a spray person they mite know what they are?
