messages problem
messages problem
messages problem
Ralph Drouared
I am only getting the comments of WW members. I am not getting the original question.
Re: messages problem
Dan Donaldson
Do you see the entire thread when you click on one of the responses? Depending on your settings, you may see only the replies on the main board if the original has scrolled off from time. If that is the case, when you click on a reply, you should be able to see the entire thread.
or...
...you can go to Set Preferences (in the gray navbar above the Messages Index headline) and change your time window. By default, it will be 4 days for this messageboard. If you change it to, say, one week, you will pick up threads that were started within the past week.
If you prefer a table layout -- you might want to set your List Style to Compressed List.
