We value your privacy.
I'm building a serving tray using Morado (aka. Pau Ferro), and am looking for suggestion of how to finish this type of wood. Its very dense, oily stuff. I'm assuming that my favorite Waterlox finish would not be a good choice. Would wipe-on Poly work better? Should I apply a sealer coat of Zinner seal coat first, then apply a finish coat of my choice?
I would wipe it down with Acetone before applying any finishes to remove the surfaces oils. The dewaxed shellac would make a very good barrier coat. You are correct that oil based varnishes are not usually the best to use on oil woods IMO.
Nitro lacquer is my favorite finish, but dangerous without proper ventilation. Love nice Morado!
Because that is a naturally oily wood, and oil based finish can be problematic if applied directly to the wood.
A way to deal with it is to wipe the surfaces down with acetone or lacquer thinner keeping a fresh face on your wiping rag for each stroke. Just sort of swirling the solvents on will just move the oil around without removing it.
The second step is to apply a barrier coat of dewaxed shellac. Zinsser Sealcoat or Zinsser Spray Can shellac will work. Apply and let dry overnight. Do not sand the shellac.
Next, apply the first coat of your clear coat. Let is dry and sand with 320 sandpaper. Then apply a couple of more coats of your clear coat.
Both Waterlox Original and poly are varnishes. There are only minor differences between them. Poly is slightly more scratch resistant and heat tolerant. Waterlox has a much nicer appearance and gives up little in the way of scratch resistance and heat tolerance. Because of the nice wood, I would choose the Waterlox Original.
