Sparaying Lacquer
Sparaying Lacquer
Sparaying Lacquer
Greg Muller
A question to those who spray Lacquer. What brand of Lacquer do you use. I will be attempting to spray Lacquer for the first time useing a Earlex 5000 but don't know whart type and brand to use and would like to practice some before i do the piece that I want to spray. Thanks.
Re: Sparaying Lacquer
Clint Searl
Sherwin-Williams
Clint Searl
One part nitrocellulose or acrylic.
Clint
Deft
Ken Oakley-Sunny St. Cloud, Fla
They have a sanding sealer, a semi-gloss and a High Gloss. Have used it for years and never been disappointed.
Fred Davis
Whatever the paint store is currently stocking , which generally is Gem brand and I use Pre-Cat Lacquer with it's recommended Vinyl sanding sealer, in every sheen but Gloss.
I wouldn't go near a Sherwin -Williams store. It's the Harbor Freight version of a paint store.
FredD
McKinneyMike
McKinneyMike
You can't be serious are you? SW finishes are some of the finest available IMO. I have never read anything close to a negative comment about any of their finishes and I know of a lot of pro finishers that use it and maybe ML Campbell exclusively.
Harbor Freight? That is rich :)
Clint Searl
Clint Searl
You must be doing something wrong, Fred, I've been spraying S-W one part solvent NC, acrylic, and alkyd lacquers on bare and stained wood successfully for more than 25 years. Flows well, no orange peel, any sheen, dries hard, good price, and easy to rub out.
Clint
Fred Davis
Clint , for someone who doesn't espouse the recommended sanding sealers for Lacquer , I am doing something wrong?
I didn't comment on S-W Lacquer , I said stores.
For the following reasons, their help is not knowledgeable about finishes , never have worked in the field as a Painter or someone like me who sprays a lot of Lacquer or use a lot of paint, who when asked a question about their Oil based Wood Filler , said what?
Paint contractors like them because they have a "Contractor grade Paint" which is not a top of the line product.
Paint contractors in Ca when I worked there used primarily Kelly - Moore products owned bu Bob Moore who I know personally.
S-W for many years had a good rep in the construction industry , if you actually check around , you will find that to be less true anymore .
FredD
Thomas S Stockton
I went into the local Kelly Moore store in Redding CA and asked if they had tung oil, the worker told me I should go to the super market. He was serious and had no idea what I was looking for. It all depends on the store, some are good some are bad but comparing Sherwin williams to harbor freight is wrong in my experience and implies that they sell an inferior product.
Tom
Re: Deft
Greg Muller
Ken,
Do you thin the Deft at all or straight from the can. Also do you use conditioner and sanding sealer.
Re: Deft
I usually thin with lacquer thinner 50/50. Most times I apply 2-3 coats of sanding sealer. then sand and apply the lacquer. Buff it out with 0000 steel wool and a good paste wax.
del schisler
i use M.L.CAMPBELL sanding sealer and simi-gloss for yr.s and no problum. It is a cabnet grade hard finish. I belive that company is own by shurman willian's. But M.L.CAMPBELL they make their own product's. As far as compairing them to harbor freight.?? I don't do any harbor freight at all mite be something ok but i don't have time to take stuff back tell i get something that work's. my 2 cent's worth
Chuck Jurvelin
I can't even imagine someone comparing Sherwin-Wms. to Harbor Freight!
I have sprayed lacquer for darn near forty years and after trying just about every brand out there, I primarily use S-W Precat High Build and
love it. It dries fast, flows out good, and holds up well. As for the
S-W stores and employees, I couldn't be more satisfied. You can run into jerks or idiots in any business, but the S-W employees I have dealt with in Minnesota have all been great! Most problems with any of your leading brand finishes are caused by the person holding the sprayer.
Fred Davis
Like I said , I was talking about the dismal service.rather then the Lacquer and if I had to live in Minnesota to get the service your speaking of . well......................
As for stores Thomas , I asked for where the Spar Varnish was in a local hardware and was told they didn't have that brand.
As for service, maybe many of you have never experienced trading with a professional Paint store that was run and staffed by retired Painters rather then walkons.
Sounds like Harbor Freight could use a upgrade too
FredD
Re: Deft
Greg Muller
Ken,
If you use stain do you use the sanding sealer after the stain or before. And how many coats of lacquer. I usually use three coats of poly but have read that lacquer requires many more coats to build like poly.
Re: Deft
Stain first--then a couple coats of sealer, then how ever many coats of lacquer till I like the look. normally 3 or 4.
Steve Schoene
The thing is that there are S-W consumer stores--mostly architectural coatings and the like, and then there are the less common professional stores that have the higher end products--and expertise.
FredD
You mean like borgs , Steve ? :b :D
FredD
