Blade changing
Blade changing
Blade changing
Ed O'Neill
I have a John Deere LA105 ride on lawn mower that needs new blades. Is there an easy way to change the blades short of bringing it to a dealer. My thinking is to drain the oil (needed anyway), tip the machine to one side after pulling the spark plug wires and raising the deck as high as possible Any help would be appreciated. Ed
Re: Blade changing
Re: Blade changing
Dave Paine
Before you try turning this over, I would consider removing the deck.
If you do not want to remove the deck, do you have any car ramps or axle stands? I would raise the front and then you should have access. Just have to crawl in from underneath.
I do not have this model, but I did the same concept on mine once. I did not want to remove the mover deck and wanted to sharpen.
Re: Blade changing
Moses Yoder
Re: Blade changing
Moses Yoder
We always removed the deck on my dad's rider. Should have instructions in the owner's manual. And also thought I would mention if you have a grinder you can sharpen the blades yourself. Just put them on a wood dowel to see if they are balanced. If you don't sharpen yourself, take them to a small engine shop, should cost less than new blades and they will be sharper than new blades. Lawnmower blades need sharpening about once a year anyway.
Re: Blade changing
I've sharpened mine ...
Mike Farinella
using just a mill file while the blade was in the vise.
Re: Blade changing
Just pulled the deck on mine
Phil Joines
It took about 5 minutes. Of course, I've done it a few times before.
I pull the deck3 or 4 times a summer to both sharpen the blades and clean all the grass that gets packed underneath.
To hijack the thread is there any paint that can be used on the bottom side that won't get blasted right off? Maybe powder coat?
Re: Blade changing
Re: Blade changing
Fred Davis
I use a floor jack on the front end of my John Deere and I change blades when the tips of the grass from the last cutting are showing they are dead and that is more like four changes a season after mowing two and a half acres every time.
FredD
Re: Blade changing
Jim DeLaney, Austintown, Ohio
Re: Blade changing
I run mine up on a pair of ramps, then use the Deere blade locking tool to keep the blade from turning while I remove the bolts (15 mm wrench).
I sharpen the blades by holding thim in a vise and using an angle grinder.
I mow about 1� acres, and resharpen the blades about six times a season - more often if I inadvetantly run over a rock or something.
Re: Blade changing
Re: Blade changing
Jim Dillon
Ed,
I jack up the front of my 37-year old Jacobsen with a car jack, then have at it. I usually use a glove on one hand to hold the blade securely. I then grind the blade on a grinder moved into the driveway so no sparks hit the sawdust in the shop. Not perfect, but good enough considering all the rocks, limbs, roots etc. that I traverse over. Someday I might take the blades to a local shop for a professional touchup, but until then... .
IIRC, the first time I took the blades off, the bolt was darn hard to loosen. I had to jam the blade with a piece of wood and extend the rachet handle with a piece of pipe to get the leverage I needed. After that, loosening the bolt became much easier.
Jim
Re: Blade changing
Re: Blade changing
FredD
Buy a Breaker Bar and the right size socket and use a dab of Lithium grease on the bolt threads. Works great, now if I could get it up to waist height to work on.
FredD
Re: Blade changing
Re: Blade changing
Jim Dillon
Fred,
Thanks for the tip regarding adding a touch of grease to the bolt threads. I will sure do that next time.
Regarding the use of a car jack (scissors style), I should have mentioned that I jack the front end up until the front wheels are clear then slide a stack of 2x6 cutoffs under the front end and lower the mower onto the cutoffs. I feel safer that way. It is still a tight sqeeze reaching under the mower, but workable.
Jim
Re: Blade changing
Re: Blade changing
Ed O'Neill
Thank you for all of your suggestions. Blades changed successfully. Ed
