Plans for Log
Plans for Log
Plans for Log
Bill Allen
Hello again!
A few asked me to keep them informed on my project after I posted pictures of the wild log I want to dry. I have taken many suggestions to heart and come up with a few ideas of my own.
Below are a few more pictures of the log, now cut in half (each piece is aprox 30" tall), including a shot of the center grain. My plan for drying is to paint the ends with Kilz 2 primer to seal them, then drill 4-5 2" holes through the center of each piece (tight grouping, hopefully less than 6" in diameter) for ventilation. I'm going to prop each on a pair of 2x2's in my dry basement and then using cardboard, create "funnels" with 4" computer fans at the top to cover the vent holes and draw air through the logs.
If anyone sees any glaring mistakes or has suggestions, please advise. Think it might be dry enough in a year to work on?
Re: Plans for Log
Moses Yoder
Re: Plans for Log
Moses Yoder
Is the log pretty dry now? It looks like it came from a dead tree. I hesitate to advise you because I don't have any experience drying logs, just boards. But I know the worst thing you can do to lumber is dry it too fast, which you might be doing with your fans. If the log is pretty dry now, like 15% or so, the fans probably wouldn't hurt it.
Re: Plans for Log
Re: Plans for Log
Bill Allen
The exterior is pretty dry already but I don't have any way to tell what's going on inside. I know the log was cut last year, sat outside over the winter and that loggers took the rest of the tree with them, so the wood must have been solid and usable when cut. I don't know what fresh cut hard maple has for water percentage, but I imagine the inside still carries plenty.
In sealing the ends, boring out some of the middle and using the fans to create air flow I am hoping to encourage the wood to dry more evenly, thus reducing stresses and large cracks.
Re: Plans for Log
Clint Searl
Re: Plans for Log
Clint Searl
Whatever you do or don't do, it's gonna split, so why do anything? Finalize the table design and trim the pieces to their final configuration. I think they'd look great onder a glass top in a trestle arrangement.
Clint
Re: Plans for Log
Re: Plans for Log
Bill Allen
They will be the base for a large glass topped dining room table.
Re: Plans for Log
Re: Plans for Log
Bill I don't think drilling the holes will accomplish anything useful. You have to dry it slowly. I have been drying thick blanks for platters but they are mostly side grain. What you have is mostly end grain. Personally I would coat it with parafin wax and plan to wait many years for it to dry. The faster you try to dry it the more likely it will crack. the wax will eventually chip off as it starts to dry and shrink. These cracks will speed up the drying. You might save it this way. I've been pretty successful on smaller things but never tried something that large.
The other alternative is to let it crack and then either fill the void or use the void as part of the design. I have never tried it but I have always wondered what would happen if you go ahead and make a cut down to the pith. I have cut many logs in half through the pith and they still crack further but that's because they have been stored outside in the weather. Thicker bowl blanks that I have split out the heart and sealed the end grain with wax hold up really well when left my garage with concrete floor.
Re: Plans for Log
Clint Searl
Re: Plans for Log
Clint Searl
The only way to possibly prevent the logs from splitting is to immerse them in a solution of polyethylene glycol, which will replace the water. If you've ever had a colonoscopy, you know what it is.
Clint
Re: Plans for Log
It's already cracked to the center.....
Dick Coers
so it will just open that up as it dries. There will be no stopping that crack. It looks to me like it was a lightning strike tree with all that color and with that big radial crack. My big concern would be "wildlife" inside the wood. Powder post beetle eggs are a very high likelyhood. Semi-rotten wood can also have other insects in it as well. As rustic as that thing is, I vote let it check, no holes. Good luck!
Re: Plans for Log
Re: It's already cracked to the center.....
Bill Allen
Wow, this is a bit of a turnaround from the advice I got a few weeks ago, or at least how I interpreted and drew up plans from. Different folks�.. http://www.woodcentral.com/cgi-bin/messages.pl/pro/search/pmd/sread/srchid/22186iqzYSa87w5IwEBY1305391504/spage/1/sanc/435556/sbid/1000/md/read/id/435614/sbj/how-to-dry-log/
Let me be clear - I believe they are going to split as well. All I�m trying to do is minimize that splitting as best I can � knowing full well that nothing may work. I�m also hoping that by this time next year I can use the wood as a base for a large glass topped dining room table, so I kind of want to get it dried ASAP. I�m going to drill my holes, run my fans, WAX � not paint � the ends (thanks!) and hope for the best.
I have done a lot of work with 4� to 6� slabs of hardwood end grain and have learned to incorporate the voids into the work. A couple of representative tables can be found on my website.
After the log has dried for 12 months (fan running) I�ll send it to my kiln guy who will cook it at 185 degrees for a couple weeks which should kill anything living inside it.
Thanks for your insights!
Re: Plans for Log
Its looks to me like the center has already started to rot. I tend to agree with your approach. I would want to remove the center, as much as I could and run the fans but just barely have air movement. I think slow air movement would help keep the inner surface from mold. I might also try dosing it inside with Clorox or Timbor or Boracare.
