Water based dye for oak floor
Jay Lombardo
Can I use a General Finishes water based dye on an old red oak floor after sanding it down. They have a dark brown color that the customer ( my sister) is in love with. I used the stuff on a maple entertainment center for someone else and now she wants me to do her floors that color. I have never used water based dye on flooring before and was wondering if I am asking for problems. Also, if it is OK to use it I am assuming I could use a clear High Gloss water based Poly over it. Any thoughts??
Thanks,
Jay
Re: Water based dye for oak floor
A waterborne finish (I use only Bona Mega) will suck a waterbased dye up into the finish layer and look muddy unless you seal the dye in with a sealer like shellac. If you go to outfits that deal in floor finishes, you're find oil-based dye stains as well that, once dry, won't bleed You may also like their color better as there will be more differentiation between summer and winter grain with the oil than with water based, giving a livelier grain to the floor.
Note as well that you can tint your waterborne topcoats although it should not be much or you'll have lap marks all over the place.
If you go with the water dye, raise the grain with water first, re-sand lightly, and vacuum off well before applying your color. You may have to repeat the re-sand and re-dye if the water dye raises more fuzzies. When dry, apply an even coat of 1.5 pound cut of 100% dewaxed shellac as a sealer before putting on the top coats. Bona says three coats of its top coat, min 4 to max 12 hours apart. It will then take 6-7 days to cure to 80% so light (socks - no shoes) traffic and no dogs.
Good Luck
Steve Schoene
The General Finishes product you mention is not your typical dye. It is a dye in a binder. In my opinion, that will make it harder to use. Because of the binder you have to apply and wipe off excess like most stains. But, being water borne, it will dry fairly quickly, giving little time to apply and wipe off. At the very least it would be a two person job with one to apply and one to follow behind wiping off (with perhaps a go fetch person to help). Having a binder means you have only one chance to get it right, and you could get streaks if you can't work fast enough to keep a wet edge.
A powdered water soluble dye would be easier to use, I think. You would adjust the shade by adjusting the concentration of the dye mix so that it ends up the right darkness if you flood it on. You would want to wipe up puddles. The powdered water soluble dye can be adjusted--darken by another coat after it has dried or lightened by wiping down with water. You can even use chlorine bleach to remove it if it has turned out horribly. There is a risk that the dye might not "take" inside of pores, which sometimes seem to have a waxy coating. If that happens you would have to follow up by sealing the surface and applying a pigment only stain to lodge in the pores. You do have to seal the powdered water soluble dye before using a waterborne finish.
Oak accepts oil based stains well. You have more time to work, and the only tricky part is making sure you wipe off any bleed back from the surface. That means you have to check on it every 15 minutes or so for a while. Stains with pigment do give a much different look. The pore structure would be emphasized while with dye it would be minimized.
As far as the top coat, you want to use a finish specially formulated for floor. Some ordinary high gloss varnishes would be too slippery to be safe. Floor finishes need to meet a friction specification. Water borne polyurethane finishes such as Bona Kemi Traffic or Mega or Basic Coating Street Shoe are highly regarded.
PS
Jay,
I checked General's website, and it seems to say that its stains are not for "architectural" use. That may indicate that they're not for your intended use so check it out before you jump.
Thanks
Jay Lombardo
Wow, thanks Mark & Steve for the informative responses. It sounds like I would be asking for trouble. I'm thinking maybe it would be better (and from the sound of it, easier) to find an oil based pigment stain that is close to the color she likes and stay a little closer to my comfort zone. Again, thanks for the help.
Jay
Re: Thanks
Andy Halterman: Carving the singletrack
Both Bona and DuraSeal (commercial division of Minwax) make oil based stains that dry in 2-3 hrs. Once dry, you are good to go with any waterbased poly for your topcoats.
You'll probably have to source them at a local supply house. They both normally run about $35-40 per gallon. Worth the extra $$ since they dry in a timely fashion.
Bon chance!
Andy Halterman
All the rain is making my lawn into an urban jungle in Hendersonville, NC�
