New Hybrid Table Saw! *LINK*
Re: New Hybrid Table Saw! *LINK*
For a couple hundred more you get a full 3 horse machine also with a riving knife. Not sure that hybrid is a "deal" depending on what you'll be doing. Occasional slice and dice is one thing, but if you're planning on putting a lot of wood through the saw, I'd pass up the white paint and step up a notch.
m
Only that . . .
s mackay
. . . I've got two Griz machines. Love'em both. Can't wait to up-grade my others to Griz standards !
Re: Only that . . .
FrankG
I have one Grizz machine that I bought many years ago before supervision or ? changed. After many repeated e-mails and phone charges I will never buy another.
Re: Only that . . .
Dale Penkala
Well I just got back from checking it out & in all honesty I'm pretty impressed with the saw. Had the opertunity to run it and cut a little with it and it is a very smooth saw. I did the nickel on edge test and it did it with out any wobble at all. Totally surprised me! The guy that owned it had MANY Grizzly machines and had nothing but good to say about them. I've heard some storys about them in the past too but more good than bad. I've looked at the Jets, a Delta model, Craftsman, Ridge saws and of the models I've looked at this Grizzly stands out over all exept the Delta model that I looked at. That model was over 3000.00 so really not a good comparison but allowed me to see the difference between a 800.00 saw verse a 3000.00 saw anyway. 3000.00 is way out of my price range so the Grizzly is getting the nod at this point. I'm going to go to another wood shop next week to see what else they have here in the Mid-Michigan area.
Another thing I like about the Grizzly is they give the 6mo free financing. Not that I need it but anytime I can use someone elses money without taking my money out of the bank I'll do it.
Dale
Mid-Michigan
Dale Penkala
Ok talked with another place a little north of me and they recommended besides the Jet the Shop Fox model 1748 hybrid. Problem is I can't find any real good info on them. I haven't seen a real good picture on the net either. Does anyone have this saw or any other model of Shop Fox saws?
Dale
Mid-Michigan
Re: Only that . . .
Dale Penkala
Ok just found another website that states the Shop Fox is actually owned by Grizzly. One guy said that this was stated by Grizzly when he called. I did call and Grizzly did confirm this but couldn't tell me the difference bettween the Shop Fox & the new Grizzly Hybrid. Just that they are very similar.
Dale
Mid-Michigan
Moses Yoder
Holy Rusted Metal, Batman!!!
Moses Yoder
Over $700 just for a saw just to cut straight lines! Why, I can buy a perfectly good hand saw at a garage sale for $1! And you thought a $170 square was expensive!
Re: Holy Rusted Metal, Batman!!!
Dale Penkala
Absolutly no comparison. Besides I wasn't the one complaining. I just explained what you can do to fix the squares.
Jim DeLaney, Austintown, Ohio
The ShopFox and Grizz tools are pretty much the same tools, with different paint jobs. Parts are interchangeable 'twixt the two.
The main difference is that ONLY GRIZZLY sells Grizzly, and Various licensed vendors nationwide sell the ShopFox.
BTW, I've had the ShopFox cabinet saw for nearly ten years now, and it's been rock-solid reliable, and dead-on true. I recommend it highly.
Steve Schoene
I'd be very happy if I had the skills to cut accurately straight lines with a handsaw.
Dale Penkala
Thanks for the tips Jim. Yes I'm finding this out about Grizz & Shop Fox machine tools.
Dale
Mid-Michigan
Re: New not a Hybrid Table Saw!
Chuck Lenz
In my opinion, it's not a Hybrid unless it has cabinet mounted trunions.
I thought
Phil Joines
they had both an electric motor and a gas engine :D
Dale Penkala
In both cases (the Jet & Grizzly) the trunnions are mounted to the top. I'm not sure about the Shop Fox. I don't no about the other hybrids. My understanding of a hybrid is the motor, belt & pulley assembly is mounted inside an enclosed cabinet which allows it to have a better dust control system.
Typicly the motors have a more power than a contractors saw but not quite the power of a true cabinet saw. A happy medium if you will. I expected the jet & grizzly to have had cabinet mounted trunnions but was surprized they weren't.
Also from what I'm told the cabinet is better built on the hybrid than on a contractors saw (not just a formed sheet metal frame) but not quite the thickness of a true cabinet saw.
I'm not sure if I missed anything else that makes the hybrid different but thats all I can think of at the moment.
Dale
Mid-Michgan
Chuck Lenz
Unfortunately there isn't a set industry standard on what can be called a Hybrid table saw. I've noticed that Makita is now labeling their Jobsite saw as a Contractor's saw, and Steel City is now labeling their Hybrid saw as a Cabinet saw.
