Lumber rack question *LINK*
wilbur
I want to install a lumber rack on a cinder block wall. My plan is to get the system that I linked to below. On the wall I plan to attach 2x4's flat against the wall with expansion anchors, which is a method that I've used successfully before, and then attach the vertical lumber rack straps to the 2x4s with lag screws.
The reason why I'm not attaching the vertical straps directly to the wall is that I'm not sure that I'll be able to put the anchors where I want them due to the position of the holes in the vertical straps. If I use a 2x4, I can put the anchors exactly where I want, and the 2x4 will give me more than enough flexibility in positioning the lag screws and the vertical straps.
Because the 2x4's are going to be flat against the wall, I'm limited to using lag screws that are 1-3/4" long at most. What I'd like to know if this is going to be enough to hold the vertical straps to the wall. I will be making sure that the vertical straps are resting on something that is connected to the ground.
Lumber rack system that I'm going to get
