Veritas - Innovation in Tools
Bandsaw tire wore out prematurely
Starry S Chan
The bandsaw tires on my three-month new Grizzly G0513X2 wore out prematurely after occasional use. The blade somehow bit into the lower tire and created a 1mm high ridge behind the back side of the blade. The upper tire also wore but it is not as bad as the lower tire. It looks like this might have been caused by over-tensioning and heat generated during sawing. I tensioned the blade using the fluttering method and it is within the range suggested in the user's guide. I have used the fluttering tensioning for many years so I think I got it right.
I had a Delta 14" bandsaw for over 6 years before this larger bandsaw and I did not encountered any tire wear at all. My Delta bandsaw had urethane tires and the Grizzly has rubber tires.
Any idea what I have done wrong and how can I prevent this from happening in the future? Also, do you know where I can find urethane tires for Grizzly bandsaw?
Starry
Re: Bandsaw tire wore out prematurely
Grizzley service
Jerry Gibbs
Check with Grizzley, they have excellent service.
Leo Cuellar
Leo Cuellar
I've had a G0555 for about 6 years now with no issues on the tires, using many different widths of blades. I would check the alignment of the wheels & guides after you get the tires replaced.
No they don't
Terry Quiram
What Grizzly has is good lip service. I have a machine less than 1 year old that burnt out the motor. I was told a replacement part would not be available until the 3rd week of June. If customer service was so great then they would drop a motor into a FedEx box and send me one from Tiawan instead of putting it on a container ship. I am not a happy camper.
Dale Penkala in Mid-Michigan
Hello Starry
I've had my grizzly 555x for couple of months with moderate use and I too used the flutter method for tensioning. So far so good! At some point I'm planning on doing urathane tires as well. Woodcraft has them but I'm planning on doing the carter or timber wolf urathane tires.
Here are the links:
Timberwolf
http://www.suffolkmachinery.com/urethane-band-saw-tire-price-list/
Carters:
http://www.carterproducts.com/product_list.asp?cat_id=15
Hope this helps! Keep us posted on your issue with this please
Dale
they don't have a motor to send you ???
del schisler
on the motor i would raise some hell over that and tell them they don't have a motor that will fit the saw?? I would tell them that they will loose busisness over this , that you check into lot's of wood web places and you will just spread the new's over them ?? Or give me a new saw. How can they expect you to just let it set. You bought it to make money from it and that you are loosing money. If they had a returm i sure would get it back to them. That is why i don't buy from those company's . Of course they don't make them but they should have a back up of part's. Like they don't have a motor that they could send you . Crap on that.. my 2 cent's
Hot Sawing
Lee Schierer McKean, PA
If your blade got hot, it sounds to me like your tension was too low and the blade was slipping on the drive wheel. I'm not a heavy band saw user, but when I've resawn, I don't recall my blade ever getting hot. I could see where if the tension is low on a high Hp saw that the drive wheel could slip, generating heat enough to melt the tire while making a cut. I don't think this is a warranty issue for Grizzly.
If the ridge is on the drive wheel and is only 1 mm (.039") high, take a file and with the wheel running, carefully file down the ridge or replace the tire with a new tire from Suffolk Machine.
Lee
excellent hypothesis
Bill Tindall
It sounded like the owner was worried about over tension so it may have been too loose, and that wear is exactly what would happen. Indeed a blade should never get hot. For resawing I crank the tension to the max. I can get it (for a 3/4" blade.)
Flutter Test
Is great for general work while cutting stock up 3" or so, but as the thickness increases above that, the beam strength of the blade is reduced proportionally to the distance between the thrust bearings. When resawing, I increase blade tension with a strain gauge and a chart. I've had the same set of tires on my 18" JET since it was new 11 years ago.
It sounds to me like two things were combining here. First, not enough tension on the blade was allowing the blade to slightly stall in the cut, letting the drive tire rub as in short dash intervals; increased roughness in the cut is a good indication of this. Second, if the blade was not optimally sharp, the increased drag in the wood will create more heat. Combine the two and even urethane tires will get toasted.
Re: they don't have a motor to send you ???
Terry Quiram
The motor is on a metal working machine, a mill. I have already asked them to take one off a machine in stock. I will call tomorrow and tell them I want a replacement machine.
Starry S Chan
Thank you for your comments.
Tensioning is probably not the issue as I am familiar with the blade tensioning technique. I did find out that the two wheels are not co-planer with the top wheel tilted backward by 3/32" to 1/8". But I did not observe any tracking problem.This may have been the reason why the blade dug itself into the back side of the tires to create the ridges. I assumed that the wheels are aligned at the factory and I did not bother to verify it.
I knew that in a couple of instances when I was cutting bowl blanks out of almost dry wood using green wood blade. I was lazy and I did change to a blade for dry wood. My feed rate also might have been too aggressive. The combination of wrong blade and feed rate might have created heat. The tires are rubber tires and they probably cannot stand much heat.
In any case, I called Grizzly this morning and told them about my problem. They are very generous to send me two new tires. I will be much careful with these replacement tires by making sure that I use the right blade for the cutting task at hand and to be gentle regarding to the feed rate.
BTW, Suffolk does not stock tires for 17" wheels. These have to be custom ordered. I have not check with Carter to see whether they stock tires for 17" wheel.
Starry
Dale Penkala
Starry I just checked at Carters site and they have the 16" & then jump to 18" tires. Sorry about the mislead! :(
Dale
In Mid-Michigan
