Veneer Error
Veneer Error
Veneer Error
Doug Reynolds in Seattle
I made a rookie error on a veneer glue up and glued the veneer veneer-tape side down. I used water based Pro-Glue Veneer Bond Dry Resin. This is two pieces of veneer glued to a 1/4" panel of Baltic birch for a door panel on a small box. Am I out of luck or, will it still work? I do not want to take any chances it will delaminate later. Thanks for the input.
Re: Veneer Error
Re: Veneer Error
Jesse Cloud
I think you know the answer. If you do not want to take any chances, the only path left is to start over.
I think the piece would probably not delaminate, but the shape and texture of the veneer tape will telegraph through the veneer.
Re: Veneer Error
Re: Veneer Error *LINK*
Thomas S Stockton
Did you use the special gummed veneer tape with holes or some sort of masking tape? According to vacupressing systems if you used the three hole tape you don't have a problem. Follow the link about halfway down is the tape.
Tom
http://www.vacupress.com/accessories.htm
Re: Veneer Error
Worth a try
In all my years of veneering stuff, I've never heard of a paper tape that goes on the glue side of the veneer. It is hard for me to fathom that this could not result in a loss of adhesion between veneer and substrate at the tape locations, but maybe it is so porous that the glue is able to saturate the tape or something.
I'd like to hear some test reports on this. Big news to me if true.
