Re: Best way to raise a platform bed
Steve Schoene
You still need a sturdy base, legs that work at 12" tall and solidly attached to a bed platform, don't fair so well when extended to 36", with an iffy joint between them and old legs. For that matter even making new, longer legs is still a bit suspect. The longer leg increases the leverage against the joint.
One idea is to make the new base in the form of a dresser with 4 or 6 drawers in a sturdy case that supports the bed frame.
When you raise the height you also need to add rails and some sort of ladder.
