Your experience learning to spray?
Bill Tindall
For the benefit of someone just starting, how did you learn and what equipment have you tried successfully or not?
Someone showed me and I have only ever used a professional Binks or DeVilbiss gun. Are there useful books? A mentor certainly would be helpful. Maybe some local woodworker or someone at a local cabinet shop would demonstrate. Oddly there are classes on every detail of woodworking but not spraying a finish.
Will a cheap spray gun yield success in the hands of a beginner?
There are variables that are important that are hard to explain in words. The following applies to conventional guns which are easier to learn on.
1.The pressure at the gun needs to be optimized. Too little pressure and the spray comes out in too large droplets. You can see these large splats on a practice target. Too little and a fog comes out with poor transfer efficiency.
2.The viscosity of the finish needs to be some minimum value or the finish won't suck up in the gun. This is more a problem in thinning oil paints enough to spray.
3.The feed rate needs to be adjusted so that a moderate coating is applied. Too high a feed rate and there will be runs.
4. Finally, the distance of gun from target is important, again for transfer efficiency.
5. I think most important is good lighting so you can see the film as it hits the target.
I can teach someone the mechanics of spraying in minutes, or you can teach yourself. Get a piece of cardboard and fill the gun with colored water. Spray to get a uniform overlapping coating. Each pass should half lap the last pass. It is the other parts that a mentor would be handy. Spraying on a practice surface might be all that is required to get down the basics. Sometimes I just spray at something flat to see how the coating is laying down before I begin.
Lacquer is very easy to learn to spray. It is formulated so that its viscosity steeply increases as the solvent evaporates (4th power of solids concentration for those mathematically inclined). Hence, runs are uncommon. Paint is prone to run but it is the easiest to learn to spray a uniform coating because it is easier to see the result, than on a clear film. Water based finishes are the hardest to spray in terms of run potential. If you can spray water you can spray anything.
