Have a question? Ask Woody!
Question on spraying finish....
When you spray finish, do spray "into" the wet surface or outward toward the dry surface? (I am using rattle cans at the moment, but I suppose it applies to spray guns as well)
Re: Question on spraying finish....
Moses Yoder
Moses Yoder
I spray outward where possible toward the unfinished area, so there is less overspray on the finish. Similar to brushing, you want to keep a wet edge, starting at one side and working to the other.
del schisler
I spray lacquer all the time. Always spray away from you. Start closest to you from right to left. I guess that wouldn't make a difference left to right. But away from you is the only way to go. With lacquer don't come back to you with the spray you may get run's . On a flat surface i have sprayed comming back. This make's a heavy coat. So watch ? been doing this for yrs. now my 2 cent's
