REAL MILK PAINT
Anyone recognize "Jofco" office desk
Frank on Chestnut Hill
Gentlemen,
I am in the process of taking apart a "Jofco" large vintage office desk in order to get into its' future abode (my son's) home office. I see how the 2 pedestals are attached with 6 screws each. That is the easy part. With any luck the top will come off and begin to allow me separate the 2 pedestals from the knee hole "kick" panel.
That is where the question lies. I see a square glue block with 1 screw one each side. The one screw is into the pedestal side. Has anyone broken one of these down? I don't have the top off yet and can't tell if the "kick Panel " is dadoed in to the pedestal sides. And worse yet dadoed and glued.
This is really a heavy mother and any experience breaking down a commercial desk like this would be a great help. Once this thing is in its 4 major parts ( top, 2 pedestals and the kick panel ) it will be easy.
Thanks in advance.
Re: Anyone recognize "Jofco" office desk
Re: office desk
Don't know the brand but I've taken apart several 4-piece office desks.
To do so I lay the piece front-down across a couple of 2x's and a blanket after taking the drawers out of the piers; one we put on its top. That allowed access to the screws that hold the top to the piers as well as (with a reach) to piers to the vanity panel. Screws were usually set with 2 on the outside edges one on the front off-center toward the vanity and 1 in the middle of the inside of the piers, and then one or two in the top stretcher above the drawers. Vanity was held by two screws on either side from the inside of each pier. Had one that had a pocket hole screw in the middle of the vanity into the top.
Good Luck
It oughta come apart
Having worked for one of the contract furniture manufacturers for seven years, I've seen a lot of contract furniture and virtually all of it is assembly line stuff, where finished parts meet up at the cabinet assembly line and are put together with screws and miscellaneous hardware. You should be able to demount the top first, followed by the modesty panel.
I wouldn't worry about glued joints, but y'never know. :)
Good luck,
Re: It oughta come apart
That nasty modesty panel was screwed and glued. We got one side to "part" with little damage and just left the other side intact. We can get it in place with the panel still attached to one side. I would have bet a couple of bucks that it would not have been glued. Thanks for the input.
FFG
