Brush on lacquer
friend2
Has anyone tried the new brush on lacquer by min-wax?
Brush on lacquer
friend2
Re: Brush on lacquer
Don Orr
No help here-didn't even know they made one. Might have to try it.
advantage of lacquer vs varnish?
Bill Tindall
While I am aware of brush-on-lacquer I have never tried it so I am unaware of its potential advantages. My understanding is that brush on lacquer is typical cellulose nitrate lacquer formulated with a slow evaporating solvent. So in the end, presuming technique was optimum, the result would be the same whether it was brushed or sprayed.
But for myself, the advantage of lacquer vs varnish is that lacquer can be sprayed. It dries quick enabling rapid re-coat and hence rapid completion of finishing. When I think about brushing something I think varnish. Varnish typically offers better durability than lacquer.
What are the attributes of brushing lacquer that would make it preferred over varnish if one must brush?
FredD
Deft is the most popular and well known of Brushing lacquers.
Like Shellac you need to develop a brushing technique that puts on a full wet coat in a single pass and never go back over it , until it has dried
FredD
Re: advantage of lacquer vs varnish?
Steve Schoene
The advantage is still that it dries much faster than varnish. And, lacquer is easier to rub out than varnish because it is so much harder. It would collect a lot lest dust, but that's not relevant because I can't brush it so perfectly that it wouldn't need rubbing out. With varnish I could apply it not to have brush marks or other defects. But, if there is any dust, anywhere in the universe, some of it ends up on my varnish, so I still have to rub out.
But, lacquer is in my mind only a smallish notch more durable than shellac, while varnish is a much bigger step above lacquer.
