A55 Smoothing Plane
need help with slider
McKay
I have this jessum table slider that I really like. The problem is... do I have the fence in the forward location as almost all sliders, or do I have it in the back position? If I use it for cutting angles, then the fence needs to be in the back because of the scale location. Most of my cut offs do not exceed 16" in width.
Re: need help with slider
Thomas S Stockton
I usually keep the fence on my slider in the back position, in this position it is easier and more convenient to use. The main reason for the front position is it is easier to heft a full sheet onto the saw without trying to get it over the fence at the same time. On some saws with 4' sliders you can only crosscut a panel from the front position.
Tom
