Raising the UNDERSIDE of the roof???
Kneale Brownson
I have a garage with eight-foot walls and trusses. I'd like to alter the bottom of the truss system to create a space with at least a couple more feet of height.
The 2 X 6 trusses are 22 feet across and the peak is 10 feet above the bottom of the crossmember. The 2X4 bracing is six feet in from the crossmember ends and three feet below the peak. I'd like to add a new crossmember about three feet above the existing one for all but the two trusses at the gable ends and then eliminate the lower crossmembers.
The sketch shows approximately what's there now and a dotted lines of what I'd like to do. Can I do this? Should I add additional angled bracing?
