OT - Porch repair question
Joe in a Cleveland suburb
Hi all.
The outer ends of my porch need to be repaired (again). This is a 1924 house.
Each end of the porch extends beyond the roof by about 8 or 10" and takes a beating from the weather. The original flooring appears to be white oak (total guess, but looks like oak). They are about 2-1/2 wide and maybe 4/4.
I replaced these boards about 8 years ago with some kind of T&G porch flooring from a lumber yard. I had to modify it to approximate the current T&G. As I recall, it was just pine.
Anyway, my question is, because the flooring extends beyond the porch structure and is unsupported underneath, how do you nail it into place? Just shoot nails straight in from the side?
Any suggestions on material to use? I thought about using some PT and milling to be like the old T&G in place now, but I really don't want to put that wet stuff through my planer/jointer and so on.
Thanks for any advice.
Joe
Re: OT - Porch repair question
The treatment on pressure treated lumber usually penetrates only a little below the surface. The inner core of PT lumber is often just the wood as it came from the tree. I've taken to getting all my PT lumber from the local contractor's yard, because I know they specify Douglas fir (which is moderately durable in the ground); some of the Borg PT lumber is of species that, on their own, won't last in the ground. I can testify to that from experience, having had to prop up some fence posts that are hollowed out in the middle after less than a decade.
Our porch has a similar construction. I screwed an aluminum* angle to the framing, bringing it out as far as I could and still hide it behind trim pieces, to support the outer bits of flooring.
*Were I redoing it - and, who knows, I may have to at some point - I'd have a sheet metal shop bend up the thickest stainless steel they have to make an angle. More expensive, no doubt, but more durable, particularly against the pressure treated framing of the porch.
Redesign?
Dave Bair, Eaton Rapids, MI
Can 8-10 inches really be that important to the esthetics of your home? Why not shorten your porch so that it's covered from the weather and resolve your structural issue of unsupported flooring at the same time.
