electric mini random orbit sander
ken chase
The Metabo is the only small (31/2") RAS I've found. I will appreciate opinions
about this model and recommendations of any small RAS that is electric.
Thanks
Ken
Re: electric mini random orbit sander
David Barnett
Smaller than the Metabo yet still electric *LINK*
David Barnett
There's the variable speed 2 3/8" MicroLux combination sander and right-angle drill. It required a transformer-converter to 12VDC. There are cheaper power supply alternatives to the one offered in the linked catalog page, btw.
Also, I amended (on edit) my initial pneumatic recommendations on the Hand Tools side to include a link to the Proxxon variable speed detail sander, which might also be an option.
MicroLux Heavy-Duty Right Angle Disk Sander / Dril
Nick Tuzzolino
I have had one for about five years. I find it to be a very solid, well built machine.
I don't use it as often as the discs on my Sioux, because it does not afford much flexibility on reaching in very far. With a drill motor setup, you can use an extension if need.
It it excellent on large, broader areas, like large bowl surfaces.
It can also be used with a vacuum (small) attachment.
