glueing tip for beginners
Bill Tindall
When learning to edge glue panels one can "glue-and-hope" and wait for a season to see if the technique was successful. That's the way I learned, but quicker feed back on the joint quality would serve one better.
Typically the next step after gluing a panel will be to trim it to size. The cut-off can be used for quality control. Break the joints in the cut off and see if there is wood failure at each joint, indicating an acceptable joint. The picture shows a cut-off available for testing as well as a cut-off that has been tested and found to be acceptable (wood failure at each joint).
Re: glueing tip for beginners
PS- lumber end checks
Bill Tindall
The red observed in the picture is the paint mills often put on the ends of lumber packs for identification. Where you see red is the ends of the lumber this panel was prepared from. Note how I was confident, in this particular case, to use portions of the lumber that were very close to the lumber ends. The cut-off confirms this confidence. If there was a board end check the cut-off would have readily separated at each check(split/crack) and revealed itself. Hence, the cut off can be used to both test the glue joint as well as confirm that no end checks have crept into the panel.
I have no rules of thumb for how much to reject from lumber ends. It is a case by case decision made on the basis of what I see.
