Problem with wenge table top splitting *LINK*
jsheaney
I made a hall table out of wenge and cherry and delivered it just over a year ago. (Please see the link below.) It has been through all of the seasons here in Rhode Island. It sits indoors, of course, and doesn't get a great deal of direct sunlight. There's no air conditioning in the house, so there is no protection from the seasonal humidity changes.
The table top is connected to the base with sliding dovetails, which seem to be doing a good job. The dovetails poke out and withdraw as the seasons change.
The problem is that the table is splitting at one end. In the picture, you should be able to make out a pattern of hairline cracks that kind of look like shattered safety glass. Some of them have penetrated the top, which I think you can make out, as well. Most of the cracks in the finish are fractions of an inch, but there are many. One or two might be an inch long.
I describe the finishing I did in some detail on the project page, but it's basically a couple of coats of Bush Oil (an oil/varnish blend). On the top, I filled the pores and then put a few coats of poly and then rubbed it out.
Does anyone have an idea of what went wrong? I suspect the wood wasn't dried properly or maybe I didn't cut enough waste off the end. It seems like a really weird pattern of checking, though.
Is there anything I can do about it? I've had suggestions of retrofitting the ends with breadboards. I don't think it needs breadboarding for stability because the sliding dovetails seem to be doing that job. I think the idea is more to just cover up the splits. It seems to me that the assumption in that repair is that the splitting won't progress any further. How long should I wait?
I don't know if there is some way to seal the endgrain. I'm concerned about doing anything that will add any material into the splits. I would imagine that any material would ultimately just act like a wedge and lengthen the splits.
I don't really know what to do at this point. Any suggestions are welcomed.
Hall table project
