Foam brushes and shellac-YES!
Bill Tindall
Foam brushes do particularly well on flat surfaces when applying shellac. Unfortunately one has to work quick because the brushes with the wooden handles disintegrate after a few minutes exposure to ethanol. The white upholstery foam does not disintegrate and I use pieces of this white foam for applying shellac to things spinning (slowly!) on a lathe.
Today I was shellacing drawer insides and tried a foam brush I recently got as a pack of 50 from Woodworkers Supply. One buys plastic handles and the foam insert is replaceable. To my delight this foam is immune to ethanol.
BTW, I dilute Zinnser shellac 1:1 with ethanol, soak some up in the foam brush and with a light touch brush in one direction on the drawer sides and bottoms, applying a very wet coat. Sand with 400 grit and recoat. Dry and wax the outsides and the maple runners. Drawers glide like they are on ball bearings.
