Kitchen remodelling......
Jesper, Denmark
Jesper, Denmark
Some time ago, we had a discussion about using wood panels as backsplash for my kitchen counters. Despite advice to not use wood and not to use a dark color for the cabinets, I did - and quite like the results.
The panels are hard maple. The wall behind the cooktop is pickled stainless steel.
The cabinet and drawer fronts were just removed and painted, building new was time and cost prohibitive, and if the color did not work, they can be painted again.
The fear that the kitchen would be too dark did not materialize. The effect is that the dark color recedes into the background and the lighter walls and wood surfaces step into the foreground.
The kitchen is in a 1928 built brick house, so any radical modernization would be out of character. The floors are pine, untreated with any finish, except the occasional washing with a rich soap solution. That treatment is also traditional, but from much earlier than the last century. They hold up surpisingly well - any spill just takes a little scrubbing if you do not get to it right away.
Re: Kitchen remodelling......
Well Done
Creating contrast between the cabinets and the tops enlivens the room. I do prefer more differentiation between counters and backsplash area, but for me, there's no better material for wet/splatter areas than stainless
What did you use for your wood finish on the counter tops? Hope it was something that's easily repaired/renewed.
Yonak
I like the look a lot, Jesper. The green really looks great, especially with the stainless appliances.
Jesper, Denmark
Re: Well Done
Jesper, Denmark
The counter tops have a solvent based floor finish, three coats, semi-gloss.
The panels are modified tung oil varnish, also semi gloss. The green is also an alkyd e�namel, again semi-gloss.
the gloss level here is referred to in %, so 100% is a mirror and 0% is totally flat, no reflection. semigloss is 50% reflection.
FredD
I have done a lot of Kitchens in my work life Jesper and I must say that is a very unusual back splash and very good looking.
FredD
