OT - Plastic Welding
Anyone here do any welding of HDPE sheet material?
I have to make a sandwich from 2 sheets of 3/8" HDPE that is then welded around the perimeter to make an air-tight seal.
Tool recs welcome along with do's and don't's.
TIA
Re: OT - Plastic Welding
Plastic Welding
Jon M
Many, many years ago I worked at a mountain ski shop were I was taught how to repair gashes in ski bottoms and repair torn PE ski boot shells with a plastic welder. I'm not sure if the HDPE you have is the same, but close enough I suspect.
1. What tool are you using? I currently own a cheap HF plastic welder that I've used on my own ski bottoms and the hole that the horse kicked into the rubbermaid water trough. I works off an air compressor and line voltage to heat an element in the tip. I seems to do the job.
2. You need welding "wire", so to speak. A spagehetti strand of the same or better grade of plastic that you wish to weld.
Do you have access to those 2 things?
Clean/virgin material is needed. Use a dremel type tool with a pointed bur to reveal fresh plastic to either side of the seam to be welded. Keep contaminents off the plastic (body oils included).
The goal will be to not puddle in the plastic weld rod, but just to melt it's surface and the surface of the material to be welded and let them fuse together. Air bubbles are not allowed. You do this by directing the hot air flow out of the tip at the area just ahead of where you are laying down the plastic rod. The rod should be doubled back on itself so you are pushing it down into the groove. I'll take a picture of what I mean if you want.
You can rasp it down, use a plane, or a scraper to finish it off.
Experiment a lot first.
I hope that helps.
Not what you asked, but...
There was a show on TV where a woman/host/craftsman made mostly contemporary furniture, often out of non traditional materials. She made a chair that Had a plastic seat and back and a metal frame. I believe it was HDPE. She glued it. Found some super duty industrial adhesive. As you can see, I don't remember the name of the show or her name so take this with a grain of guacamole but I recalled the glue because I thought HDPE could not be glued. Now if I just knew what the glue was.
Already Checked
Manufacturer informed in in no uncertain terms that HDPE cannot be "joined" with any adhesive. There are glues that will work to "sort of" stick things to it if you rough the surface, but they are not structural bonds and will not take pressure. The only methods are mechanical (screws/bolts) or welding. Since I am remaking the air lifter for my lathe that sandwiches neoprene between 2 HDPE sheets, I'm going to have to either weld the outside edges closed, or find somebody local who can do it for me.
Pretty much what I thought.
There's a thought. I should check one of the local ski shops to see if they could do the weld-job for me. I've got about 9' lineal to be welded. If it's cheaper than the $65 for the Harbor Freight tool. I'm done.
Thanks Bill
Re: OT - No Cigar
Local ski shops didn't work out and the only plastics fabricator wants $120 (minimum shop-order) to weld 9 lineal feet of seam. Looks like a trip to Harbor freight is in the near future. Hate having to buy tools that I'm likely to only use once.
A possibility
Gary Camp, Bend, Oregon
I have had metal fab shops let employees use equipment on their own time to fab items that wern't worth the shops time. but could put extra money in an employee's pocket. Might it be worth a ski techs time to do that project on the side? Would a shop rent the plastic welder? Most of the ski techs I know would do the job for a couple of cases of PBR ;-) 'course I live in sort of a ski town and there are a goodly number of folks who would do many things for a couple of cases of beer.
glc
Re: A Shortage of Staff
The shops here have switched over to pool sales & service, so their ski-techs get furloughed until about October when they start the "Last Year's Models" sale on ski stuff.
I'll just have to look on the bright side. Years ago I bought a set of Router template guides but never used them. Didn't even think I had the required parts. Lo and behold, I went searching through boxes neatly stashed in another part of the basement, and I find the special plates to mount the bushings, the centering fixture, all the necessary screws, and a 1/4" down-cut spiral router bit, all sealed with a desiccant packet in their Ziplock bags, nicely labeled for the routers they fit, along with instructions.
Having neatly put away those tools that I bought but never found a use for, I've lived long enough to have profited from my previous extravagance. Christmas in April! Perhaps I'll live long enough to be able to reuse the hot-air plastic welding set. If not, my kids'll be going through my stuff and it'll be just one more "Dad's Tool" mystery for them to figure out. :D
