Mirror Cutting
Mirror Cutting
Mirror Cutting
Jon M
Question: Is it just like cutting glass, or will I wreck it?
I have a 36" x 30" x 1/4"thk glass mirror with a 1/2" chamfer around the edge. I am designing a frame to mount it in, but I want the mirror to be proportioned differently.
The dimensions I want are 36 x 24, so I want to trim 6 " off of the long edge.
Ultimately the edge of the mirror will be captured behind the frame such that it will hide the existing chamfers, as well as the cut edge.
Any words of advise?
Re: Mirror Cutting
Jason Roehl in Lafayette, IN
Re: Mirror Cutting
I bet a local glass shop would cut it for a whole lot less than a replacement mirror--probably only a few dollars.
Jason
Re: Mirror Cutting
Cutting a large mirror
Lee Schierer McKean, PA
I had a large 1/4" mirror that I wanted cut down. The local glass company did the cuts for me for about $1 per cut and I got the left overs if I wanted them.
Lee
Re: Mirror Cutting
Re: Mirror Cutting
pete labelle
A basic glass cutter tool with a good wheel. Add a drop of light oil to the wheel. Hold a straight edge to the mirror and in one stroke, make a COMPLETE score from end to end. Hold over the edge of your bench and give a firm push to the tail.
Glass must be scored 100% of the line, else a crack will originate in the wrong direction from that point.
Re: Mirror Cutting
Re: Mirror Cutting
Jesse Cloud
Agree with all the advice above. Its just like cutting glass. BUT, if you don't cut glass regularly or don't have the tools for it, or if the mirror is valuable or sentimental, a glass shop will do it cheaply.
Re: Mirror Cutting
Re: Mirror Cutting
Jon M
As usual, the obvious never occurs to me at first. I've cut glass before, but only thin stuff that wasn't too big, so why chance it?
I have a glass shop less than two miles down the road. If they charge me anything less than $10 I think it's worth having them cut it.
Thanks!
Re: Mirror Cutting
Age issue, too
Older glass is often harder to cut accurately, so if this is a vintage mirror, it's yet another argument for having the glass shop cut it.
Re: Mirror Cutting
Age issue!
Jon M
How did you know about my age issue?!!!
Oh, you meant the glass....yeah it has a few years on it, but if age were a contest, I win over the glass.
