Cleaning Pressure pot and hoses
Thomas Norton
When I spray solvent based products I use the appropriate solvent to clean up. But when I use waterbase water alone does not seem to "do'it'. I was wondering what you guys use? I thought I heard that amononia was a possiblity.
Thanks
Re: Cleaning Pressure pot and hoses
Jason Roehl in Lafayette, IN
Water will EVENTUALLY do it, unless there's dried material. Ammonia does help a lot--you can even add a little dish soap. Lather, rinse, repeat....
Jason
Re: Cleaning Pressure pot and hoses *LINK*
I'm assuming you're asking about waterborne material. Here's what I do.
A. I never allow finish to sit in the rig. If I'll be interrupting spraying for more than 30 minutes, I drain all finish and rinse with water. BTW, I use polyethylene liners in my pot.
B. When the spritzing is done, I first rinse well with water, then add several drops of Simple Green and 1/4 cup of DNA to a pint of water. I'll then pressurize the pot and spray about half the mix. Shake and tip the pot to get to all surfaces and let sit for 15 minutes then spray the rest.
c. Rinse well with water, then put a quart of clear water in the pot and spray it all out to rinse the material hose and the gun.
General Finishes sells and a gun rig cleaner at the link, but the MSDS list no ammonia
General Gun Wash
Moses Yoder
Moses Yoder
For your pressure pot, I would suggest using a liner like these http://www.finishsystems.com/pressurepotliners.html . You can get them at about any finish supply place and they usually run a couple dollars apiece. For water base finishes though I have always just scrubbed my stuff with a green ScothBrite pad and water. If you get a buildup of hardened finish somewhere, you can remove it with stripper.
I don't have a spray rig so take this as second hand information. My friend is a professional cabinet maker and has such a rig. I noticed that he has a gallon can sitting inside the pot. I have not discussed it with him, but my assumption was that that way the pot never got any finish on it and thus did not need to be cleaned. To clean it or change material, he lifts out the gallon can and puts a lid on it and then puts in another with the appropriate solvent to clean the gun and hoses.
Thomas Norton
I used amonoia and a bit aof dishwashing soap alonh with hot water and the clean-up was quite fast.
Thanks !!
mdclor
After thoroughly rinsing with water, I will run a little DNA through the gun to ensure that there is no water remaining. The DNA evaporates quickly and leaves no residue. HTH
