Plastic or metal threaded rod?
I've been asked to make a set of processional torches. The candles that they use are oil filled candles. They have a threaded socket (1/2" x 13 tpi) in the bottom.
I was thinking about drilling a 1" socket for the candlesticks. Then I thought about just using a threaded rod. Now I'm thinking about using both a socket and the threaded rod (or bolt). I figure if the candlesticks were screwed in, they wouldn't come off easily.
The candlesticks are nylon or some similar plastic. The thread is (as I said) 1/2" x 13 tpi. I can easily get metal 1/2" bolts or all-thread from the local hardware places. Should I consider trying to obtain plastic bolts or threaded rod or just go with the metal? McMaster Carr has nylon and other types of rod available at a reasonable price.
