Lettering a plaque?
Lettering a plaque?
Lettering a plaque?
I've been asked to make and letter a plaque. As my printing is abysmal, I need help. I was thinking about either using a router or a Dremel tool.
The plaque could be about 18" or so wide - so I can put some reasonable sized letters on the plaque. Anyone have any suggestions?
TIA.
Re: Lettering a plaque?
John Veerkamp
lots of places (craft stores, hardware stores, even Wally World) have letter templates. There are a variety of sizes and scripts out there. You could even blow up letters on your computer word processor to the desired font size , print them out and use that as templates.
Moses Yoder
Moses Yoder
We used to have a cnc router that would engrave just about any font you throw at it. You could check with a local router shop, if you can't find one ask a kitchen cabinet shop where they are. Another option is a lazer engraver, those shops are pretty much all over now too.
If what you want to do
Gary Smyth
is paint, then go to a quicky sign shop with the dimensions or better, take the back plate and have them make a vinyl lettered template. They have thousands of fonts and will do it letter by letter or machine write it out with the proper spacing, letter thickness and kerning. You can get it in stencil or as a overlay and cut the letters out on your own. Then paint. You could also go to a trophy shop and they may be able to put what you want on a larger metal plate which is fancier but not easily read unless the reader is close to it. You can then mount the plate on an elegant wood backer and contrasting mouldings. If you have the bucks, a place like U.S. BOAT or a decent marine chandlery has sources for boat name quarterboards with letters that are hand cut or routed and filled in with paint or gold leaf. And then there are the commercial sign shops with metal, plastic, letters cut out in all sizes and fonts that you can attach with glue, epoxy, construction adhesive. Ebay has tons of places for letters.
Lettered signs can be rough or finished but they are a specialized skill. It's not the lettering that is difficult, it's the spacing. On a sign of 18" wide, a 1/8" out of bounds is glaring. Go for it if you want to make the effort, but for the novice to do it well, graphically "cheat" every way you can afford. Signmaker router templates won't make you happy and if you do it by hand routing use something that limits your degrees of movement.
steve mackay
Sounds like you'd really like to DIY it. I've tried for years. Dremel, carving knives, all kinds of ink, etc, etc. Even borrowed an old Leroy lettering rig. Always looked amature-ish. I asked around and found a trophy / awards shop (actualy only a block away) that had a laser engraving rig. Asked the pricing and was shocked. So long as you go with "stock" stuff (what is already programed into the machine) it is VERY reasonable. Last one I did for my BIL was, like, thirty letters and was only about twelve bucks. Looked clean, neat and professional. They can "set" the depth so that it can look as though it is only engraved on the surface or deep so you can "float" some stain in it. For the heartache and frustration of DIYing it, turning it in and getting a GREAT result in a day or two is well worth the outlay. Good luck !
Alan Young
Re: Lettering a plaque? *LINK*
Alan Young
You've been given some good suggestions JL. If I had thought to inquire about some of those options I might have done so on this recent project---
Here I just drew everything in sketchup and played around with different fonts. Once we arrived at the font we liked I printed out each letter to scale and attched it to some 1/4 MDF with spray adhesive. I cut out the letters on my band saw-even used the 1/2 blade. A little filing around the edges then I sprayed the show surfaces and glued on to the substrate.
-Alan
Memorial Wall Art Piece
I'll check with the local sign shop.
