REAL MILK PAINT
does masking tape help tearout
I was just asked by a friend if putting masking tape over a surface before you cut it helps keep the chip out of the veneer from happening. I didn't know for sure so I thought I would ask the experts. I think I've tried it in the past with poor results but it's been too long. I generally try to use a finer tooth blade or in worse cases use a sacrificial board underneath to support the fibers. What do you all think.
Re: does masking tape help tearout
Re: does masking tape help tear out
I have tried it but have never done an A/B comparison. I am certain tape won't turn a crappy blade into an excellent one. My recollection is that the tape might have helped, but also pulled out the chips and fibers leaving me to wonder if it really helped. I have better luck cutting the face veneer with a knife and then cutting it. The knife cut "stops" the chip out.
Help?  Yes, but it depends more
Gary Smyth
on the blade, the orientation of the wood and the saw type. I've had better luck scoring a line with an exacto knife at the cut line. For me it's a more reliable method.
I use it on ply. Benefit depends on the veneer. Maple and birch it helps, but nothing stops Meranti from splintering. :b
To get the most benefit, I score the cut line with a razor knife, use a high-count blade, and orient the piece so that the blade enters the wood on the more important (top, show, etc.) edge of the cut. If using a circ, rather that a table or RAS, an edge guide, regardless of how good you think you are with the saw, helps a lot as well.
FredD
Scoring the Veneer before the cut works best, that's why better Tablesaws have a scoring blade running ahead of the main one.
FredD
Sometimes
Lee Schierer McKean, PA
I've used masking tape to reduce tear out and it works fairly well. It won't over come a dull or aggressive blade, but it does help. You have to use the White masking tape with the high adherence, not the less stick blue or purple painters tape. I run it right down the cut line and make sure it is bonded well to the wood. When removing the tape after the cut, peel the tape toward the cut line not away from it. Pulling away from the cut line can add more tear out.
When cutting plywood with a jig saw I use the Bosch Progressor T-234X blades with little if any orbital action, which will yield a very smooth cut with minimal tear out.
Lee
Re: Sometimes
thanks for the info. A jig saw is what got this conversation started. I told him I wasn't sure the tape would help at all but the best bet was to get a finer tooth blade. He was cutting holes in his desk for cords so cutting from the bottom side wasn't an option.
Why didn't you say so?
Neal in San Jose
There are jigsaw blades that cut on the down stroke for just that sort of application. I've used them successfully on plywood and high pressure laminates, and always have a couple of sharp ones around for these odd cuts. They do take a little getting used to - they will make the saw try and jump up in the air - but once you get the hang of them with a little practice on some scrap, they work very well.
Sounds Like a Job For
HOLESAWMaaaaaaannnnn!
[to get a clean edge underneath, pack the area with books topped with a piece of 3/4" for the saw to cut against. The install yer wiah gromets n' she be dunnnnnn.] :D
Re: Why didn't you say so?
Don't use the T-234X blade for cutting curves, it won't work unless it is a very large radius. You can also make a zero clearance insert for your jig saw that will reduce splintering.
Lee
