OT laptop battery
OT laptop battery
OT laptop battery
Jim Runchey
Just wondering what the proper care/usage on a laptop battery is. Is it harmful to let it run all the way down?
Re: OT laptop battery
Define all the way.
You should discharge it once in a while - get it down to a minimal level (10-15%). You shouldn't leave it plugged in all the time (DAMHIKT) or you will lose capacity on the battery.
Link on  laptop battery charging *LINK*
del schisler
here is a link on battery charging
http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_batteries
John McGaw
There have been three different major technologies used in laptop batteries over the years. Each has different characteristics and require different care to maximize their life. Modern lithium (ion/polymer) batteries are quite forgiving of abuse and require little in the way of special care. All I bother to do is to run the "battery calibrate" process a couple of times a year so that I will know approximately what the computer means when it says that I have X% charge left.
not so
Bill Tindall
The lap top battery is undoubtedly a lithium ion battery if the computer is fairly new.
Certain configurations of nickel cadmium (NiCd) batteries coupled with certain chargers led to a phenomena that the public called the "memory effect". If certain NiCd batteries were not fully discharged they would not fully charge upon charging with some charging schemes. Hence, it entered the folklore that batteries needed to be "run dry" from time to time to retain their full capacity, and this notion is true in some situations.
The service life of a battery is most determined by the sophistication of the charger, as well as the temperature of charging and discharging (heat is very bad). . It happens that lithium ion batteries are the least picky about charging, given the fact that the device they are in has management electronics that limit the battery from overcharging (which would lead to its blowing up) or over discharging which would lead to its permanant loss of capacity. According to my friend that works in research at a battery company most all batteries like to be about half charged. For example the Prius battery is never charged much beyond 50% nor discharged much below 50% and by this means battery life is acceptable.
Given an appropriately sophisticated charger there would be no down side to leaving a battery on charge all the time. But who knows what the quality of the charging electronics might be unless one buys a high quality(and price) dedicated charger.
In your case battery life will be extended if you don't let the battery run dry and stay that way.
BTW, a lithium battery never runs dry in use. The battery management electronics shuts the device off at a preset amount of discharge to protect the battery. But if this battery then sits it will continue to self discharge and loss of life will result.
good link with some caution......
Bill Tindall
Lithium ion batteries are the newest general battery chemistry, which leads to two cautions when providing data on this battery type such as found in this link. There are a variety of lithium ion battery chemistries where the anode, cathode and/or electrolyte differ. Each chemistry has its particular details, for example battery voltage at XX% charge, charge discharge characteristics, life, etc. Improvements in battery chemistry are being developed at a rapid rate. Hence, specific data such as detailed in this link may, or may not, apply to the battery you have in your device, for example % capacity loss under this or that condition.
The general conclusions for the care and feeding of this battery type described in this link are, however,spot on, for example the effects of heat (Bad!). Who ever wrote the description of the battery chemistry in this link doesn't understand it. Any battery works by coupling a chemical oxidation with a chemical reduction and the link offered no clue as to what is being oxidized and reduced in this battery type. ( lithium and cobalt is the answer for one common type)
