The Biiiig Fill
OK, Here's the scenario:
Assume a slab at least 8/4 thick that has holes (large, small, bug trails or galleries, rotted out limbs and bark inclusions)
Assume that some will be left as "working voids" while other will be filled solid all the way through the slab.
It was suggested to me to use sun-dried used coffee grounds and Titebond III instead of epoxy. The reasoning was that as the wood swells with seasonal change, the glue mix will do likewise and remain level whereas the epoxy, being rigid , will wind up either above or below the surrounding wood.
Let us keep in mind, now, the we're talking 2" thick fills, and if it's a big hole, we're looking at pouring a pint of resin at a time which will take special hardeners and a slow cool cure to control.
So, what say ye, gurus? Titebond? Epoxy? Coffee? Wood flour and sawdust?
