Has anyone had a hinge do this before?
kellyanderson72
It is a "solid brass" hinge from Lowes. I guess it is solid brass because it aged pretty well but the screws just turned silver after the ammonia.
I soaked them in lacquer thinner to clean off the clear coat then to speed up the process I soaked them in the ammonia instead of just fuming it.
I installed them on the project, an aquarium canopy it is just a flat plywood lit banded in solid wood attached to more solid wood. I installed the stay and when I lifted the lid to try it out the hinges just broke. At first I thought the screws had pulled out but when I looked this is what I found.
Could it have been the soak in the ammonia that did it? Or just bad hinges?
I bought 2 more pair at the same time and did everything the same to them but they installed with no problem. Any ideas?
