Anybody know binary numbers?
What is binary for 2?
A friends son had a tee shirt that said "There are 10 kinds of people that understand binary numbers, Those who do and those who don't." It was meant to read "2 kinds". I thought 2 would be 01, not 10.
Re: Anybody know binary numbers?
Dustmaker Mike
Howdy binary is really pretty simple. Lets count to the number 7
000 = 0
001 = 1
010 = 2
011 = 3
100 = 4
101 = 5
110 = 6
111 = 7
Easy enough
Jason Roehl in Lafayette, IN
No--2 in decimal is 10 (or more likely 0010 or 00000010 or some other, longer multiple of 4 for total digits) in binary. 01 would be 1 in decimal.
Working from the right in binary the first place is number of 1s, then 2s, then 4s, then 8s, etc. In decimal, it's 1s, 10s, 100s, 1000s, etc.
Jason
Gary Smyth
Another interesting thing
Dan Donaldson
For any number base that you pick, "10" always represents the base. For example, in base 8, 10 represents 8, in base 3, 10 represents 3 and so forth.
Chuck in Mtl.
and don't forget numbers in hexadecimal(base 16) or octal(base 8) BCD or binary coded decimal used in most calculators or even time keeping which is base 60 except after the French Revolution when they tries to introduce base 10 for time keeping.
Rod Peterson�Ormond Beach, FL
I used a variant of that in my email sig for years. In the version I used it read: There are 10 kinds of people in the world: those who understand binary, and those who don't. It actually makes more sense that way. Of course you may be misremembering the exact quote on your friend's shirt. I got lots of comments from the sig which fell into 10 groups…
From a recent The Big Bang Theory episode came this monologue from Sheldon making his case for the perfect number: "73. It's the 21st prime number and its reverse, 37 is the 12th. The reverse of that is 21, which is the result of multiplying, can you believe it, seven and three. Also, 73 in binary is a palindrome: 1001001."
Binary numbers are usually (but not necessarily) represented in groups of four (the above cite notwithstanding), as in: 0010 0101 (which is 40). The groups of four are particularly convenient as each group corresponds to a complete range of hexadecimal digits. Hex numbers range from 0 to F (0 to 15 decimal), and thus 1111=F and two groups of binary 1111 1111, for example, are FF in hex, and 255 in decimal.
All that may be making your head spin, but anyone who deals in computers in general and programming in particular soon develops a facility in both binary and hex—binary because ones and zeros are the very essence of how computers work, and hex because binary numbers can get cumbersome when they get beyond eight bits. They're really very elegantly interrelated.
I'm passing facile with them, but there are some real math whizzes out there who can come up with all sorts of jaw dropping things about numbers.
Rod
You are correct, I misremembered the quote, Your version was more accurate.
I had a fiend who was a mathematician. Not sure what his understanding of binary and hexadecimal were, but he told me a story about the very origins (?) of mathematics and that there were three fundamental concepts. I should have taken notes. Now I can't remember them but as I recall one of them was that there was "oneness" or the concept that any "thing" could be represented by a "one". And that after the one was another one. And another. There is no maximum number.
Some parts of mathematics are so elegant that I suspect we did not invent it, we discovered it.
> …the concept that any "thing" could be represented by a "one"…
That's the very essence of binary—if exists=1, if not exist=0. The only two possible states. By the way, take a look at a lot of your On/Off switches (just in front of you on your monitor, for example) I/O. That doesn't stand for "input/output", it literally means state of 1 or state of 0 (zero)—on, off.
Perhaps...
...there are multiple meanings. I was under the impression that I/O were pictorial in nature--representing "closed circuit" and "open circuit", or on and off, respectively, since the "I" is usually more of a straight line than a "1", and the "O" is circular, whereas a zero is typically an elliptical shape in text.
Jason
OH..I hate to say this....I used to....
Terry Alexander
....code in binary and hexadecimal. There was a time when I could read code in hex quicker than most "kids" could in english (if you call the code we wrote "english").
Yep...giving my age away.....but in 492 days I'll start drawing SSN early at age 62.
Ah...those were the good days :)
Terry Alexander in West Texas
