Short Review-Forrest Woodworker II Option 1 Blade
Robby Wright in San Marcos, CA
I was recently looking for a blade that cut a flat bottomed kerf 1/8 inch wide so I could cut some divider slots. My Woodworker II blade has been sharpened several time and no longer cuts an 1/8 inch kerf. Besides, its kerf has a little point in the bottom of it from the grind of the blade.
I saw an ad for the Woodworker II option 1 blade and found it on sale, so I thought I would give it a try. The grind of the blade is interesting, with three different types of teeth. One has one corner clipped on the left, one on the right and one is flat across the top. I mounted it up and started shoving lumber through it. My saw is a Rockwell Contractor's saw that has a 2 HP motor, zero clearance throat plate and a Beisimeyer fence, and has been aligned so everything is parallel within a thou or so.
The first thing I noticed is that if I crosscut at the same speed as my regular WWII blade, the cut edges weren't as quite as nice as the WWII. If I slowed down the cut speed, the WWI opt. 1 blade came close. 1/2 point deduction.
The biggie showed up when I was doing rip cuts. The WWII opt. 1 rips much faster than the standard WWII and makes a cleaner cut with less burning - glue line ready. The sawdust coming off it looks much different too. It is kind of like feathery shavings, not granular sawdust. If nothing else, the WWII opt. 1 blade makes a great furniture grade rip blade. Score a point for the WWII opt. 1 blade.
Cutting plywood, the WWII opt. 1 is about a good as the WWII when cutting with the face grain. It is not quite as good in crosscut, but still very acceptable. I haven't tried Melamine on it yet.
The thing I like about it best is if you use it to nibble away stock for tenon ala Norm, it makes a really nice, flat surface. I hated doing this with my standard WWII because it left ridges on the tenon. Cutting slots for dividers, it works great. Nice clean slots with flat bottoms.
All in all, I think I am going to leave this blade on my system a while longer. It is worth the money I paid for it.
Re: Short Review-Forrest Woodworker II Option 1 Blade
FredD
Now you know about flat ground teeth, they leave the feathery dust your getting and produce the flat bottom cut and cleans out the saw kerf.
FredD
Jesper, Denmark
Jesper, Denmark
Little ridges on tenons are really of no consequence, but I prefer using a standard ripping blade for all milling type cuts on the table saw.
The option 1 seems a good compromise for a combo blade.
Ken Krawford
Robby, I actually like the "teeth" left by the WWII blade on tenons. I look on it as extra glue surface.
Typical combination blade?
Bill Tindall
Not sure from the description whether this Forest blade is a typical "combination" pattern or something new. No doubt someone that keeps up with blade technology will know.
Early "combination" carbide blades had a pattern of 4 alternate bevel teeth followed by a flat ground raker. For a while this pattern seemed to fall out of fashion in favor of just alternate bevel combination pattern. But now I see that most manufacturers offer this tooth pattern, for example Freud LU84M "Industrial Combination blade". The claim for these blades is that the alternate bevel teeth provide good cross cutting and the flat top tooth followed by the large gullet is good for ripping.
Re: Typical combination blade?
Bill - The teeth on the WWII Opt. 1 are closer to a triple chip design than the traditional combination blade with its four beveled teeth and one raker. Herei is a picture of the teeth:
Notice that there are a couple of teeth with the corner nicked off and then a raker. I also noticed that it is time to clean the blade..... :b
