time domain files
Charles in Mtl.
My question is simple...I need information about time domain files or more specifically how a frequency looks over a period of time?
time domain files
Charles in Mtl.
Re: time domain files
Moses Yoder
Whenever I need to figure the radius of a circle, I just use the formula π x R squared. I use a 4 decimal Pi equivalent of π = 3.1416.
Dan Donaldson
In what context? It might help to know what you are using it for.
Charles in Mtl.
dan,
\what we are doing is sampling a sinusoidal signal at about 31000/sec and storing this digital value on a scsi harddrive. The sampling is don in real time with about 80 channels of input. The format of the file afterwards is of a concern. I was wondering how best to manipulate this information to get something readable.
Dan Donaldson
does the sample rate meet the nyquist criteria? Can you tell a bit about the format of the output file and what you need to see? I am assuming that the sample is uncorrelated to the signal.
Chuck in Mtl.
if i am correct the Nyquist criteria says the sampling frequency is more than 2 times the highest sampled frequency. Our highest frequency is 2000hz.
Dan Donaldson
OK. What is the current format of the file and what is it that you want to accomplish with it? I am going to guess that you are reading a D/A at the sample rate and saving the readings. What is it that you need to get out of the file and how are you planning to use it?
Chuck in Mtl.
the current format of the file has a proprietary format and can only be viewed using software form them. it was my hope to be able to understand how this file comes together to allow us more flexibility during post test analysis. the information is used to check for changes in a structures integrity over the period of time during a test. the software from the manufacturer is quite clumsy and my hope was to get something better.
Dale Stansbery
What is the "31,000hz sampling rate"? Is that the output of the individual channel codec (in that case, 31Kbs) which would make more sense than the actual sampling rate which only needs to be at 2 x the analog signal of 2000 Hz. In the world of telephony, the voice band width of 4,000hz is sampled at 8,000hz and coded to 8 levels for an output of 64Kbs, 56Kbs usable and 8Kbs for signaling. that's the basis for the old 56Kbs modems.
If the 80 channels are then combined, you've introduced a whole new level of complexity of much higher data rates and packetizing
Regardless, to make sense of the signal, other than to see if it exists or not, you need to decode the signal back to it's analog state.
Addy protocol: My knowledge base for this is 20 years old: good lord, I suddenly feel old!
Dan Donaldson
you would need to do some analysis of the file format to try and figure out what they are doing, then look at the software to see how it works. From the sound of it, it looks like it could be a lot of work and analysis to try and do something different. Sounds like an interesting project, but probably a pretty good time sink.
