We value your privacy.
The son will be needing a cradle around August, so I guess this qualifies as a stealth gloat. Did a half effort google search for designs and got the usual bazillion hits none of which really were very useful. Any ideas, pictures, pointers or links would be very much appreciated. I'm sure I've got articles buried in my stacks of woodworking magazines, but haven't found one yet. Grandpa? Yikes!
First - pick a mattress size (36 x 18 for instance) and make your cradle to that size. You'll want a 1.5-2" thick mattress with sheets, "protectors" and what not.
Second - decide on a style.
Floor cradle with rockers - lot of different types and styles. Hoods are a PITA - lots of mitered joints - but a good woodworking challenge. Big problem is bending down to put the baby in the cradle.
Stand cradle - fairly standard. Basically a box with pivot points on a stand. I usually build this type so the stand can be taken apart and stored. Easy on the back. You can build the "box" with rockers so that the cradle can be removed from the stand.
Third - solid sides or spindles? If you have a lathe and can turn spindles quickly - spindles are a good challenge.
Fourth - wood. Decide which type of wood you want to use depending on the design you've chosen.
Fifth - stain and finishing. Your choice. Perhaps a conversion varnish if you have spray equipment?
There are plenty of free (and other) plans out there. If you want my notes, I can make a copy of them.
