Kitchen Cabinet Door Construction?
I want to replace all my door and drawer fronts in our kitchen. I plan to buy some sort of nice veneer. So about the substrate...
I want very plain doors....no panels. Do I just cut doors from MDF, veneer and edge band them? Or is it better to glue a hardwood frame around MDF before veneering?
Suggestions appreciated!
Tom
Re: Kitchen Cabinet Door Construction?
A suggestion
MDF is pretty heavy for slab doors, Tommy and it doesn't hold screws very well. I'd consider one of the plywood/MDF combination boards. A lot of the big manufacturers use the stuff nowadays. It is made up of a core of plywood with skins of fiberboard on either side. It gives you the flatness, stability, and paintability of MDF and the screw holding and lighter weight of plywood. I think it goes by several different brand names, so you'll have to see which one(s) your wholesale plywood dealer sells.
MDF is heavy and does not hold screws well. (both relative statements, relatively heavy and relatively poor screw holding ability, but you get it) I think if you use the euro style hinges that drill into a cup/socket holder type mounting they should work well. The edge banding may depend on what you want to do for hardware. Handles, knobs, or finger slots? I think finger slots should be cut into hardwood.
Re: A suggestion
Good to know. Thanks Ellis. Yep, come to think of it MDF is heavy stuff. So I assume I could use that stuff and avoid framing with hardwood?
T.
MDF is very stable and great for countertop substrate, but, IMHO, it suck for dorrs because of its weight and the stress put on the screws holes.
If you're going with full-flat panel doors and drawer fronts, I'd look for a) cabinet-grade veneer ply in the face veneer of your choice ($140-180 for 4x8 in my area) or b) 1/2" baltic birch ply as the substrate which you'll veneer on 6 sides, starting with the edges, to bring you up close to 11mm. This gives you meat for screws on the door hinges (especially concealed euros) by saves on the weight.
I would NOT do a composite substrate with wood and MDF as the seasonal changes will telegraph into the veneer faces.
PS
Just saw you mentioned "framing". I thought you were just refacing. MDF is NG for carcase work but MDO (ply core and MDF veneer) works well if you'll be finishing with paint/pigmented film like poly, etc.
Is this face frame or frameless on the carcasses? Inset or overlay on the doors and drawer fronts?
think about the hinges
Bill Tindall
I have little experience with MDF and none with the "modern" hinges so my concerns may be irrelevant. The failure point for traditional kitchen doors with traditional hinges are the screws that fasten the hinges on. These can loosen even in hardwood as I have tightened many on other's cabinetry. MDF doesn't seem to offer the best purchase for screw threads. Additionally a MDF door will be heavy, adding more load to the hinge/screws. Perhaps these concerns don't apply to the modern kitchen hingery but I don't like the looks of all that hardware and don't use these kind of hinges..
A relative had her kitchen redone with the most huge doors I have ever seen(and they stayed flat and secure), but I don't know what the core was made from.
Edgeband it
It's essentially plywood, Tom. On higher end veneered pieces I would typically edgeband after veneering with 1/8" solid wood edgebanding, glued on solid -- no iron-on stuff. Then, if you chamfer or radius the edges, the thickness of the edgeband goes away visually.
Some people put lumber edges on their substrate before veneering, but that's a lot harder to do especially if you don't have a Timesaver, and the thin face veneer edges are very vulnerable to dings and splintering, etc.
FredD
Why not eliminate some steps , make a nice overlay or lipped slab door with straight grain solid wood and use a upscale hinge built for weight ,like Gerber's lift off , solid polished brass , a look that shouts understated elegance.
Gerber's are a little pricey but well worth it.
Just a thought mind you.
FredD
Moses Yoder
Re: A suggestion
Moses Yoder
I know of a company here locally that would lay those up for you. They get parts cut and edge banded, I would use a 3mm edge band, then they can press the veneer on either cold or hot. I also know of a company locally that would cut your doors to size and edge band them then you could apply the veneer yourself. They use a beam saw so the door should be nice and square. They have a stick bander so can do 1/4" solid wood edging but I think I would just use the 3mm veneer edging.
Moses Yoder
Re:Hinges
Moses Yoder
If you end up using the MDO for substrate, I would use the press in Blum hinges if you are using concealed hinges. There should be plenty of shops in your area with a hinge press that can press them in for you.
