A55 Smoothing Plane
owners of Laguna Tools Bandsaw?
mike
Any feed back on Laguna Tools Band saws and mobile dust collectors?
thanks
Mike
Re: owners of Laguna Tools Bandsaw?
Michael Wilkins
Don't have any of their dust collectors, but I have had a LT-18 since 2001, and love it. Mine is the earlier version that came with the Euro roller guides and 12" of resaw. I later made the upgrade to the ceramic guides, which was a great feature. Not a single problem with the machine since purchase. Dust collection is fair, since there is no collection point near the underside of the table; but I'm sure someone could rig up a collection point there if desired. I added a Shop Fox mobile base, but Laguna does offer a mobile base made specifically for these machines. I may still order one and relegate the SF base to another machine.
I would get another Laguna bandsaw in a heartbeat if needed. Laguna is well-known for their bandsaws, and numerous sales and favorable test reports would verify this.
LT14SE
Tony Shaftel
I've had my LT14SE (12" height) for a few years. Very nice machine. I had no complaint with the ceramic guides but switched to cool blocks because I always have a small blade on it and they're easy to adjust.
Re: owners of Laguna Tools Bandsaw? *LINK*
charlie belden
Have an LT16SEC. Got it probably in 2000. Did have a sag in the table - not good if you want to cut your own thick veneer. Took about a month to get a good replacement - actually it was my original table - ground flat. THAT isn't a good idea for cast iron. The table distorted again - so I put a larger table top over the bad one - set up for resawing and made an adjustable tall resaw fence for it. Worked great and solved the sagging table problem.
Since I got into woodturning I use it more for sawing up things to turn. With a deep gullet 2 or 3 tpi in handles wet or dry wood - but you have to secure the wood so round things don't rotate while being sawn.
Click on the "Why not resaw it?" link near the bottom of that page.
http://web.hypersurf.com/~charlie2/LT16SEC/BandSaw.html
John M in Mid Mich
Have had the LT16 for 5+ years. Really love it. I use mostly my own rough sawn lumber and do a lot of resawing and rough dimensioning here before moving to other machines. A favorite activity of mine is finding some unusual bit of deadfall wood and using the combo of the bandsaw and the jointer to mill boards for special projects (hornbeam, plum, mulberry, etc.). Have made cherry and ash veneer and have resawn lots of big pieces of oak and cherry, for example to make some 1/2 inch thick cabinet back-panels so I could avoid plywood. Got mine with the mobility kit and the foot brake, neither of which I could live without. I thought about a bigger saw like the HD version (or the Minimax MM16), but as my only bandsaw, decided I'd be better off with this more versatile size. With my experience I might even opt for the LT14 if I was buying today - not sure. By the way, some people seem to have had issues with Laguna customer support, but I can say nothing but good about them. Last time I was having a problem none other than the president, Torben Helshoj, called me right back! I'm eying the dust collector, too...
Hank Knight
I have a Laguna LT 18 for about 8 years. It's an older model with 12" resaw capacity, a European motor and cermamic guides. I love it. It's done everything I've asked of it. It's very accurate and excellent for resawing. I don't (or haven't yet) needed greater than 12" resaw capacity. When the saw was delivered it came with the wrong lower blade guide bracket. I called Laguna and they had the proper bracket in my hands in 4 days from California to South Carolina. I thought that was pretty good service. I've had no other issues with the saw so I've had no further dealings with Laguna's customer service, good, bad or otherwise.
Hank
Jim DeLaney, Austintown, Ohio
I have that same saw, but with the Baldor motor. I've had it for about seven, maybe eight years now, and have sawn everything from ash to zebrawood (but mostly oak, cherry, maple and walnut) on it with excellent results. 8 inch wide, 1/16" thick veneer is super easy to do on it.
I really can't comment on Laguna's Customer Service - BECAUSE I'VE NEVER HAD TO USE IT!
Regards,
Jim D.
